2 Problems
Old Apr 10, 2013 | 01:13 PM
powerstroke84's Avatar
powerstroke84
2 Problems
Hello all, first time posting on this site!
1996 F-350 OBS PSD 150k.
Problem #1: Won't go into 4wd. Drive shaft spins, front axle u joints spin one at a time (I am assuming that is correct). It has aftermarket automatic hubs (yes I know they are junk, they came on the truck) and so I am guessing that it is the hubs that need to replaced? Is there some way that I can confirm this?
Problem #2: Check engine lights comes on when first started. Doesn't seem to matter when temp I start it at, but it's just when it is "cold" or first starting it up. If I drive it and shut it off then turn it right back on we are good. After it runs for a bit it turns off. Also it seems that it doesn't have as much power when the light is on and it idles a little lower when the light is on. Short of plugging it in to read codes anything else that I could try, that maybe you guys have run into?
Thank you very much for all the help in advance!
Old Apr 10, 2013 | 02:52 PM
Hussler's Avatar
Hussler
How old is the oil and what type?
Old Apr 10, 2013 | 02:56 PM
powerstroke84
Not even a month old, and I used Rotella.
Old Apr 10, 2013 | 03:50 PM
tshrager's Avatar
tshrager
If the transfer case will turn the driveshaft and u joints, then you've got a hub issue. I just ran into this with my autos.
As for the CEL, I personally would try to get the codes read.
By the way, welcome to FTE!
Old Apr 10, 2013 | 04:00 PM
powerstroke84
Yeah I was guessing that it was hubs. Another fella just emailed me a guide to take my autos out and re-grease them up. So going to try that and see if that fixes it or not. Yeah I figured the only way was to get the codes read.
And glad to be here, seems like a lot more support than the other site I am use to using!
Old Apr 10, 2013 | 06:50 PM
tshrager's Avatar
tshrager
And glad to be here, seems like a lot more support than the site I am use to using!
It's hard to see in this pic, but the circled piece is the wheel retaining key on the auto hubs. It looks like a half moon snap ring with a tab that fits into a slot on the stub shaft. The tab broke on mine, I'm sure along with other things, rendering them useless. If you have the means, I highly suggest upgrading to manuals. I loved the autos, right up until they left me stranded.
Hub wheel retainer nut/key-Do I need it - FSB Forums
Old Apr 10, 2013 | 07:01 PM
427 fordman's Avatar
427 fordman
You're not supposed to grease the auto hubs. When I work on mine, I clean the parts and soak them in 80/90, then install.
Old Apr 10, 2013 | 08:33 PM
ReBilld's Avatar
ReBilld
Welcome to FTE! I'm with Darin on the hubs. You shouldn't grease any hubs, autos or manuals. On the CEL, just a guess, but it sounds like maybe a bad ICP sensor. I would get the codes pulled first though.
Old Apr 11, 2013 | 09:33 AM
powerstroke84
Well that is good to know! What is this 80/90 you speak of, and where can I get some?
Thanks! Is a ICP sensor something easy and cheap that a back yard mechanic (like myself) could replace?
Old Apr 11, 2013 | 11:46 AM
427 fordman
80/90 is just oil used in the rear end case.
Is the truck missing when the cel is on or is it just lacking power? ICP is easy to change, but not real cheap. Knowing the code would for sure help.
Old Apr 11, 2013 | 12:00 PM
powerstroke84
Not missing at all, just has a lack of power and I noticed it shifts harder as well when the CEL is on.
Old Apr 26, 2013 | 02:19 PM
powerstroke84
Just one more question, I purchased some mile marker manual hubs off ebay to replace my autos. Do I need a conversion kit when going from autos to manual hubs?
Old Apr 26, 2013 | 04:21 PM
tshrager's Avatar
tshrager
Yes.......
Old Apr 26, 2013 | 04:23 PM
powerstroke84
Yes.......
Ok, are all conversion kits the same? Can I just get one anywhere?
Old Apr 26, 2013 | 04:31 PM
powerstroke84
http://www.summitracing.com/parts/mm...rd/model/f-350
Are these all I need?
