oil dipstick
Old Apr 9, 2013 | 07:14 PM
jamesg6's Avatar
jamesg6
oil dipstick
I bought a ranger with a 1978 302in for a project truck. i have besen over it with a fine tooth comb and cant find my oil dipstick. or the place for it. been through every manual. anyone have any ideas. i have redone dozens an never had this problem.
Old Apr 9, 2013 | 09:06 PM
Fordman96's Avatar
Fordman96
Shouldn't there be a hole on the block itself just above the oil pan on the drivers side?
Old Apr 11, 2013 | 10:00 AM
Flathead Red's Avatar
Flathead Red
It is either on the timing cover on the right side or the oil pan
Old Apr 11, 2013 | 08:27 PM
baddad457's Avatar
baddad457
A 78 302 will have no dipstick hole in the block. And a timing cover mounted dipstick will not work, as you have a rear sump oil pan on this motor to fit in a Ranger. (unless this is the older full size Ranger) If its the small Ranger, you'll need a rea sump oilpan with a dipstick provision in the oilpan. The Fox body 5.0 pans are the ones that work in a V8 Ranger swap, but the only pans like this were the first year's fox pans (79-1981)
brian.b
Jan 11, 2016 02:54 PM
460towrig
Dec 11, 2015 11:01 AM
xjpilot
Mar 8, 2012 10:02 AM
shack
Mar 15, 2009 08:28 PM
Goodsath
1978 - 1996 Big Bronco
Nov 17, 2002 05:46 PM
