exhaust blow back
Old Apr 9, 2013 | 04:38 PM
alexisvfd's Avatar
alexisvfd
exhaust blow back
I have a 2004 f-250 powerstroke 6.0 and when I tap the pedal and let off it blows back at me..it just started it..it only blows back for a second...any ideas
Old Apr 9, 2013 | 04:42 PM
npccpartsman's Avatar
npccpartsman
Search for turbo fart. You'll get a plethora of reading on the subject--LOL.
Old Apr 9, 2013 | 04:56 PM
alexisvfd's Avatar
alexisvfd
It aint a turbo fart it does that to when I get on it and let off..when I let off the pedal it sounds like I tapped it again but I don't..its blowing exhaust out in a short burst
Old Apr 9, 2013 | 05:10 PM
Maxium4x4's Avatar
Maxium4x4
Turbo is sticking, do you still use the EGR?
Old Apr 9, 2013 | 05:14 PM
alexisvfd's Avatar
alexisvfd
im not gonna say its not but my boost pressure on my guage is normal..i could see it doing that..idk I can take it off and clean my veins..ive don't that probably 20 times when my egr was sticking...anything else you can think off
Old Apr 9, 2013 | 05:19 PM
Maxium4x4's Avatar
Maxium4x4
If you step on it and it farts, blows black, EGR is sticking. If you step on it and feel a lag, blows a little black smoke, then takes off or farts, turbo is sticking.
Old Apr 9, 2013 | 05:25 PM
alexisvfd's Avatar
alexisvfd
egr is deleted...it just does it when I push the pedal like a inch and let off...when I step on it and let off the it whinnes..its just when I tap it
Old Apr 9, 2013 | 05:29 PM
Maxium4x4's Avatar
Maxium4x4
Back to you Tim...Turbo fart
Old Apr 9, 2013 | 06:36 PM
alexisvfd's Avatar
alexisvfd
ok ill clean the veins and see...done it 20 times
Old Apr 9, 2013 | 07:54 PM
Mich6.0's Avatar
Mich6.0
make sure your unisom ring actuating arm does not turn more than 45 deg. if it spins or pulls out all the around or pulls out then the pin is sheared, mine sheared but ring was welded to center section not used much before but now gets ased once a week
Old Apr 9, 2013 | 08:31 PM
cheezit's Avatar
cheezit
whats icpv koeo? early or late build engine?
RockinN
Apr 19, 2015 07:00 PM
KX123
Oct 23, 2010 11:01 AM
Culvert
Aug 28, 2010 04:04 PM
01PS
54
Oct 13, 2007 12:37 PM
Ben Alston
Feb 25, 2005 10:05 AM
