molding removal
Old Jun 4, 2003 | 03:15 PM
optikal illushun's Avatar
optikal illushun
molding removal
how can i remove the side molding without damging anything? also what about the f-150 emblems?
Old Jun 4, 2003 | 05:56 PM
steve83's Avatar
steve83
molding removal
Are you worried about damaging the fenders? The bodyside moulding is only held on by double-sided all-weather foam tape, so basically, just pull it off. You may have to start it with a paint scraper or flat screwdriver, and it'll almost certainly remove some paint and leave a bunch of foam tape behind. Use some automotive paint prep products to remove the adhesive without damaging the paint. (PPG, DuPont, and 3M are the best brands.)
Old Jun 4, 2003 | 10:13 PM
optikal illushun
molding removal
i meant damage the molding, im not to worried about the paint cuz the whole trucks gettin painted. i might wanna sell the molding or re-use it later down the line, also what about the f-150 emblems? arent they held on by 2 rivet type things?
Old Jun 5, 2003 | 08:21 AM
steve83's Avatar
steve83
molding removal
No - the same tape. Just don't gouge the fenders if you use a screwdriver, and take your time or you'll break the badges. It's easiest when they're HOT from the sun.
Old Jun 5, 2003 | 09:21 PM
optikal illushun
molding removal
i read a good tip, use some fishing line to get the molding off after its been in the sun for a good bit, but would heating it up with a hair dryer work? and use WD-40 to get the sticky residue off.
