Replacing the parking brake control cable
Old Apr 8, 2013 | 09:54 AM
Rovernut's Avatar
Rovernut
It's not clear in the manual. Does the rubber sleeve pictured here come out also?
The manual doesn't really say. It says using a fish wire pull the cable in to the cab, which makes it sound like that piece stays in place. But I don't see how the prongs on the retainer and all that can pull through it. I wanted to check before I force anything.
Thanks
Old Apr 8, 2013 | 10:19 AM
ctubutis's Avatar
ctubutis
The housing with the rubber grommet are attached to the pedal assembly (grommet attached to cable housing).
Only way I know how to remove the entire assembly (including cable) is from inside the cab. IIRC it's 3 10mm-head bolts... two on the firewall and one on the dash front frame. It's pretty easy and will become obvious as you take stuff apart.
Old Apr 8, 2013 | 10:28 AM
Rovernut's Avatar
Rovernut
I have the pedal assembly out and the cable removed from it. The rubber grommet (looks about 3" long) is still in place in the floor
with cable going through it. That's what I wasn"t clear about. if it should stay in place or not.
Old Apr 8, 2013 | 10:31 AM
ctubutis's Avatar
ctubutis
OIC... I have never seen it do that, the rubber has always come out with the assembly.
vwkess
Jul 13, 2025 10:32 PM
tjc transport
Mar 12, 2016 04:28 PM
mpsteil
Nov 30, 2015 07:19 AM
hunter301
Nov 12, 2014 07:58 PM
