Stalling at idle
Old Apr 7, 2013 | 09:54 AM
oldnewschool's Avatar
oldnewschool
Stalling at idle
I have an f250 with a 351 and i started it up yesterday and it has a choppy idle and it has a lag on acceleration. but when i give it gas and drive it down the road it runs perfectly fine. Any suggestions? It stalls if i let it idle with foot on the skinny peddle but it ran fine two days ago.
Thanks a bunch
Alex
Old Apr 7, 2013 | 11:46 AM
roadrash63's Avatar
roadrash63
Sounds like you're idle circuit are gummed up.
Seafoam or gumout in the tank or take out your idle screws and shoot carb cleaner in the holes.
Old Apr 7, 2013 | 12:52 PM
Franklin2's Avatar
Franklin2
Do you smell and see gas around the carb?
Old Apr 7, 2013 | 01:13 PM
oldnewschool
no i do not, and i just replaced the fuel pump and line about 1500 miles ago and i have had zero problems, i have to keep reving it so it doesn't die.
Old Apr 7, 2013 | 01:14 PM
CountryBumkin's Avatar
CountryBumkin
Also, when you use the carb cleaner spray, spray some around the base of the carb and intake to head gaskets - with the engine running. If the idle speed changes when the spray hits the gasket, you have a vacuum leak (bad gasket). You may need to get a helper or wedge something between the throttle linkage carb stop to keep it running (you want as a low as a steady idle speed as you can get before using the spray to detect small leaks).
Old Apr 7, 2013 | 03:09 PM
oldnewschool
just went out to autozone and bought myself a can of sea foam, i put it in the truck and followed the instructions and has done the trick! The engine holds its idle at 1000rpm and it also feels a lot smoother on acceleration. Thank you for all of the help and the quick responses.
RONEV
Bronco II
35
Jan 21, 2010 08:25 PM
wezol5484
Aug 23, 2004 09:02 AM
