Need help Identifying body panel section
Old 04-04-2013, 07:45 AM
aelmo's Avatar
aelmo
aelmo is offline
I have a 1968 Ford F100 4x4. I am trying to identify a section of the right cab.
It is a box shape under the right fender next to the door hinge post that serves to take fresh air into the inside cab air duct from the cowl.
Looking for replacement panel section if available.
I believe it may be called the passenger side inner cowl panel, or cowl panel assembly. Is that correct?
Can anyone verify that or know another name for it?
Is this section available as a body panel? I can't seem to find anything that looks like it anywhere.
Old 07-30-2013, 10:19 AM
luv2ski's Avatar
luv2ski
luv2ski is offline
Bump...also looking for body panel diagram ..not lmc diagram
Old 07-30-2013, 11:10 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Footwell vent bowl, cowl vent bowl or housing.
Try NPD (npdlink.com) or head over to Fordification.com
Old 07-30-2013, 12:37 PM
aelmo's Avatar
aelmo
aelmo is offline
Thank you!
Old 07-30-2013, 12:49 PM
HIO Silver's Avatar
HIO Silver
Thank you!
You're welcome. Are you looking for a replacement? To the best of my knowledge it is not reproduced. 'Gonna have to patch the one you got or cut one out of a donor.
Old 07-30-2013, 12:59 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Bump...also looking for body panel diagram.
Ask, and ye shall receive. These are the only related pics.
Fordification will have these same pics, as they're taken from the 1964/72 Ford Truck Parts Catalog.
Last edited by NumberDummy; 07-30-2013 at 01:09 PM. Reason: Ford Truck Partrs Catalog
Old 07-30-2013, 07:24 PM
luv2ski's Avatar
luv2ski
luv2ski is offline
how about all the front sheet metal diagram too!!!
Old 07-30-2013, 09:18 PM
NumberDummy
You have a 1968 as does the OP
Left upper: 1967/70 F100/350 / Right upper: 1967/70 F100/750 / Left lower: 1967/69 F100/350 / Right lower: 1967/69 F100/350 & 1970/72 F100/350.
Old 07-30-2013, 10:05 PM
aelmo's Avatar
aelmo
aelmo is offline
Sheet metal and body parts
Thank you again for the body panel diagrams. Those will come in very handy. I have got to get me one of those cd's one day soon.
I have already patched that cowl section and it turned out pretty well.
I have ordered a mustang Steves ball bearing conversion kit for the worn out clutch brake pedal assembly and installed it and very pleased with it.
I am now in the process of replacing the lower steering column bearing
F23Z3517B and I suppose I need the rubber sleeve C6TZ-3518-A.
The original bearing dimensions are 3/4" i.d. x 1-3/16" o.d. x 1/4" width.
The metal retainer cup is a little larger about 1-5/16" to allow room for the
rubber sleeve that installs over the bearing. Those parts cannot be bought from a local parts retailer.
Been wondering if I can fabricate a different size lower bearing retainer metal cup and do away with the original bearing F23Z3517B and the rubber sleeve C6TZ-3518-A and instead use a more readily available radial sealed ball bearing that has a larger diameter outer race.
Old 07-31-2013, 04:26 AM
NumberDummy
F23Z-3517-B and I suppose I need the rubber sleeve C6TZ-3518-A
F23Z-3517-B .. Lower Steering Column Bearing / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 112 = 800-476-9653.
C6TZ-3518-A .. Lower Steering Column Bearing Sleeve / Obsolete
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
PEROGIE ENTERPRISES in Highstown NJ has 1 = 609-448-5593.
F. X. CAPRARA FORD in Pulaski NY has 1 = 315-298-5114.
Old 07-31-2013, 09:20 AM
aelmo's Avatar
aelmo
aelmo is offline
When I pulled and disassembled my column the upper column had a C3DZ-3517-A upper column bearing and B1AZ-3518-A sleeve except my sleeve is metal as shown available on Dennis Carpenter in nylon.
My lower column had the correct F23Z-3517-B .. Lower Steering Column Bearing races missing the ***** and also missing C6TZ-3518-A .. Lower Steering Column Bearing Sleeve.
Strange thing is it had a upper column B1AZ-3518-A nylon sleeve up against the lower inner bearing race.
I have been scratching my head trying to figure that one out.
I think I need to remove and leave out that nylon sleeve when I re-assemble with the correct parts as shown in the diagram above there is no nylon sleeve on the lower column. Only the bearing, bearing retainer, and clamp.
I think someone must have put that there before I bought the truck.
Old 07-31-2013, 05:20 PM
NumberDummy
Previous owner installed the wrong B1AZ-3518-A nylon sleeve...either in error or couldn't find a C6TZ-3518-A sleeve.
B1AZ-3518-A sleeve used with upper and lower bearings in many applications. See 1964/72 truck parts catalog pic for examples.
Both C3DZ-3517-A bearing & B1AZ-3518-A sleeve are available from Ford. So that's where Carpenter and etc are buying them from.
And btw: Your truck did not come with F23Z-3517-B bearing originally, because this is an updated Ford part number. Replaced: C3AZ-3517-A - C7SZ-3517-D - D0AZ-3517-A - D4TZ-3517-A & B - E1FZ-3517-B
Also fits 1981/97 Escort/Lynx, 1984/97 Tempo/Topaz and a gazillion other applications dating back to 1963 Galaxies.
FoMoCo is in-famous for replacing/updating 10's of 1000's of part numbers EVERY YEAR!
Old 08-01-2013, 07:49 AM
aelmo's Avatar
aelmo
aelmo is offline
Parts interchange
Whats the chance of these parts being the same as the C6TZ-3518-A?
MUSTANG, F100 150 4X4 73-79 SLEEVE, STEERING COLUMN TUBE BEARING, D1AZ-3518-A
<TABLE style="TEXT-ALIGN: left" width="95%"><TBODY><TR><TD>1973 - 1979</TD><TD>F100,150 4X4</TD></TR></TBODY></TABLE>
or this one C8AZ-3518-A
They both are rubber bearing sleeves for different years and models.
They look the same, just not sure if their the same size.
Do you have any idea?
Old 08-01-2013, 08:10 AM
NumberDummy
Whats the chance of these parts being the same as the C6TZ-3518-A? None!
MUSTANG, F100 150 4X4 73-79 SLEEVE-UPPER STEERING COLUMN TUBE BEARING = E2AZ-3518-A replaced: D1AZ-3518-A 1 5/16" O.D. x 1 3/16" I.D. x 3/8" thick.
<table width="95%" style="text-align: left;"><tbody><tr><td>1973 - 1979</td><td>F100,150 4X4</td></tr></tbody></table>
or this one C8AZ-3518-A invalid part number
They both are rubber bearing sleeves for different years and models. They look the same (in person or in pics?), just not sure if their the same size.
E2AZ/D1AZ will not work, C8AZ is an invalid part number. Not listed in car or truck parts catalogs, not shown as being replaced in O-S-I (Obsolete-Supercede-Interchange) catalogs.
The C6TZ-3518-A (1" I.D. x 15/32" thick) sleeve part number was never replaced by another part number, like the lower bearing was.
It was only used as the LOWER bearing sleeve in 1966 F100 4WD / 1967/72 F100/250 4WD / 1973 F100/250 4WD before serial number S40,001 / 1972/73 Bronco's with P/S.
Not used with 2WD's, not used in Passenger Cars.
What are the chances of you obtaining one of the three NOS C6TZ-3518-A's I listed in post #10? If you wait too long, one or all may be sold. Once I list obsolete part numbers/sources, some parts go bye bye PDQ
Old 08-01-2013, 09:50 AM
aelmo's Avatar
aelmo
aelmo is offline
Thank you very much!
Thank you so much! I was about to make a mistake and order the wrong part. I am placing an order for the correct part now.
You have been a great help.
Quick Reply: Need help Identifying body panel section
