E450 RV ac problems
Old May 19, 2013 | 02:58 PM
maples01's Avatar
maples01
AH, the check valve, that lil $4 beauty is under the damn air box outside at the vacuum canister, over the wheel well, leaving you 2 options, pay Ford $1700 to repair it, they remove the entire heat/air unit to access under it, or cut a hole in the wheel liner. Be careful not to cut anything important. LoL
Old May 19, 2013 | 05:46 PM
bigdog100's Avatar
bigdog100
Can I just put a check Valve coming off the main vacuum line in the dash access panel?
Old May 19, 2013 | 06:53 PM
maples01's Avatar
maples01
Need it between the engine and vac canister to correct the issue, the canister is what holds the controls until the engine is producing vacuum again.
Old May 20, 2013 | 08:09 AM
bigdog100's Avatar
bigdog100
The little white tabs in this pic coming off the red and black lines off the can are those check valves because mine does not have those?
Old May 20, 2013 | 08:12 AM
JWA's Avatar
JWA
FWIW I'm about to dig into replacing my washer fluid bottle and that requires battery and tray removal. By the time its all exposed I'm of the belief these fricking vacuum reservoirs, hoses and check valve will be exposed (or close) to it by then?
If so I'll post plenty of photos in hopes of helping those facing this same issue---it seems a bit common.
Old May 20, 2013 | 08:38 AM
bigdog100's Avatar
bigdog100
Yea my washer doesnt work either
Old May 20, 2013 | 09:05 AM
JWA's Avatar
JWA
Mine works just fine, making this a bit of a PITA. Its leaking between the filler neck and main tank, not sure it can be repaired properly.
Plus I've already purchased a new Ford tank so why not?
Might be willing to send you the old one---it should fit from '92 until at least 2003---PM me!
Old May 20, 2013 | 07:15 PM
maples01's Avatar
maples01
If you had check valves on your controls, they'd not function because they are 2 way, If you can get at it by pulling the battery and tray, make plenty of pictures, and possibly video of it, I'm needing to get at it one day.
Old May 21, 2013 | 05:38 AM
JWA's Avatar
JWA
Photos for sure----I'm hoping to not encounter problems with the battery tray bolts though. Having replaced that tray in another van where the long battery bolt with top clamp had broken off, no way to drill/tap that hole so it all had to come apart. My '03 has the lower mounted battery clamp and it's not seized up so this might be a somewhat easier project one day soon.
There is another post here detailing cutting an access hole in the right side inner fender to get at the vacuum reservoir: https://www.ford-trucks.com/forums/1...efrosters.html Post #7. Not my first choice but workable none the less.
Old May 21, 2013 | 12:35 PM
95e150CW's Avatar
95e150CW
I personally just installed a new generic check valve in the feed line heading to the reservoir from the manifold. No need to pull that stuff apart. The old valve isnt going to cause any problems unless its stick closed, which seems unlikely.
Old May 21, 2013 | 06:19 PM
maples01's Avatar
maples01
Where is that line, you don't see much of nothing in the engine housing of the 97 and up vans?
Old May 21, 2013 | 09:48 PM
95e150CW's Avatar
95e150CW
Drivers side, on the intake manifold, about half way. It crosses the top of the engine compartment heading over to the passengers side. They break all the friggin time. Usually a small red hard plastic line, though in some production years it was black.
Old May 22, 2013 | 06:27 AM
  #28
JWA's Avatar
JWA
Ahh this bears some investigating then----photos of that too if I can find mine!
Old May 22, 2013 | 04:21 PM
  #29
B-O-B'03's Avatar
B-O-B'03
I was wondering the same thing, once I figure out why I only get hot air, can I put a second check valve some place?
Thanks,
-Brian
Old Jul 20, 2014 | 02:25 AM
  #30
johnlei806's Avatar
johnlei806
help
Anyone got any pics of this apparently I must have found the wrong vacuum line because this didn't work.
