Quote:
They all make a few little weird air flow sounds while in regen.
Is it really quiet, or an actual loud hissing?
If it still makes good boost out of regen, I personally wouldn't worry about it. If anything was really wrong, you'd get a check engine light.
Originally Posted by parkland
I bet it's just the software version, and normal sounds that are being made. They all make a few little weird air flow sounds while in regen.
software version? well either way it is only happening during regen... i'm just mostly curious as to where it's hissing from... hopefully i'll get a regen before saturday and I can trace the hissing sound and let you guys know... it's funny cause to me it's perfectly normal whats it's doing, and i understand why it's doing whats it's doing... but the thing is, is that it's not normal at all... lol I still feel like it's supposed to be doing it though, just because of the way it's acting.. so maybe a older software version could be right. It's in early Job 2 though... I don't know.. we'll see.
-also, it's not extrememly loud, but if I have the window down, it's easily hear... window up, I can't hear the hissing...
well my exhaust will be in today, and I'm not sure what to do, I haven't had a regen yet to figure out what this hissing is caused by, so should I wait to install the exhaust or just go ahead and do it? I mean the hissing and boost thing is only during regen so it's not like it would really be a problem again, but I'm curious to where it's coming from to be honest...
Well.. The hissing was coming from around my turbo area... Couldn't pin point it exactly... And I got the new exhaust installed.. And man that stock down pipe was rediculous to cut out... And my buddy accidently cut into the transmission dipstick pipe... It's high enough where I think it's fine for now I wrapped it in electrical tape for now... Does anybody know if that's a hard replacement item?
Quote:
Ya well it was just the tube for the dipstick for the transmission... 22$ part and I don't think it's too hard to replace.. But the truck seems to be running dang good with the exhaust on.. I like the 210 tune a lot but I don't like the transmission setting on it.. So I'm loading the 250 too see what happens.. I really thought I would still put my foot into it.. But I really don't need to cause here is so much more power... I might try the 310 if I keep up these good driving habits.. :-)Originally Posted by parkland
Aw crap dude, that sucks.
The 310 is a nice tune.
It shifts rather harsh, but then again, harsh shifting means the transmission clutch packs are engaging faster, means they should last longer at the expense of u-joint trashing.
The 310 reminds me of driving a half ton chevy with a 454 in it and a shift kit. It just makes the truck feel light it has so much power. It has a lot more power than a 454 though lol.
Parkland,
Well I went from 250 EL to late lock.. Both just really seem like they are shifting extremely rough.. The late lock wasnt as bad cause I remembered I have to train the transmission... But it still just seems to be shifty extremely rough.. Like I feel like my transmission hits a pot hole between some of the gears...
Senix,
I don't think it's my up pipe... It's not doing it that I can hear when out of regen.. It sounds like it was maybe coming from the turbo outlet to the charge pipe inlet... That area atleast.. I'm just stumped that I only heard it while in regen... But I'm deleted as of last night so I guess ill never know
Senix,
Explore
