Speedometer and odometer not working
Old Mar 31, 2013 | 02:34 PM
myfifty's Avatar
myfifty
I was installing a radio and I wanted to test it so I turned the key for power and a wire touched another wire and caused a small spark and didn't think much of. The radio is not installed yet but when I started the truck up the odometer and speedometer weren't working. I checked the fuse and it was fine. The truck is a 1993 f150, How do I fix this?
Old Mar 31, 2013 | 03:31 PM
Franklin2's Avatar
Franklin2
Check ALL the fuses. Pull each one and check it. Also check under the hood. You have a earlier truck, but they may have started using a underhood fuse box like they do in the later trucks, I am not sure when they started doing that.
Old Apr 1, 2013 | 12:57 PM
myfifty's Avatar
myfifty
Bingo! Found two broken fuses and replaced them with new ones. Speedometer and odometer are back up and running. Many thanks Frank
myfifty
Apr 1, 2013 02:27 PM
James Patrick Harris
Jan 11, 2013 08:36 AM
AK Outlaw
May 30, 2011 08:10 AM
1978fordf250
24
Feb 15, 2006 04:13 PM
QCIGUY
Oct 2, 2004 10:32 PM
