What size engine should i fit
Old Mar 30, 2013 | 06:44 AM
fordf350camper's Avatar
fordf350camper
Hi what size V8 should i fit into my ford f350 1957 i was told put in a 460 but i think this will be to big to heavy as the idea for me is to try and remove some weight from my truck by removing the twin rear wheeled axle and fit a 9inch rear axle.But would like a bit of power and a auto box thanks
Old Apr 2, 2013 | 03:43 PM
mcdonaldm's Avatar
mcdonaldm
what are you going to be using the truck for? work, play, towing, etc?
you can just about fit any motor into these trucks, depending on what you are trying to accomplish.
give us a bit more info on what you are expecting to do with the truck and how much work you want to do or are capable of doing with an engine swap.
rgds
Mike
Old Apr 3, 2013 | 01:36 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Wink
Originally Posted by fordf350camper
What size engine should fit
I would say anything from a sizes S to XL, as long as it doesn't shrink. Be sure to dry on low heat.
Old Apr 3, 2013 | 02:48 AM
fordf350camper
Hi i would like to use it every day.I have thought of a diesel and a v8 petrol i would like a auto.Its not for towing just driving well i may tow a vintage caravan
Old Apr 3, 2013 | 05:26 AM
ibuzzard's Avatar
ibuzzard
From where will you be sourcing your engine? If from the U.S., well, Gary (GBSisson) will likely give you some good input when he sees this thread. He has had many different combos in his various trucks . Me, I keep things close to stock form.
If you will source your engine from "over there" we may not be able to make recommendations, as we probably won't be familiar with what is available to you. Gary will probably know something about putting a Mercedes diesel in it, though. Good luck with the project.
Steve
62FE4x4
25
Dec 27, 2016 02:10 AM
doubledip
Jul 23, 2014 10:55 AM
mstiles19
Oct 4, 2008 09:59 AM
Southernguy101
Bronco II
Oct 29, 2005 07:23 PM
galaxiefreak64
Jun 16, 2004 06:59 PM
