Timing Cover Alignment
Old Mar 30, 2013 | 12:18 AM
Intimnasc's Avatar
Intimnasc
In the dismantling of the motor I am building the timing cover alignment pins have been misplaced. Does anyone have the specs on size and length so I can make some new ones at work or a good source for new ones? I have pretty good access to CNC machines and high precision pins and the like.
Old Mar 30, 2013 | 02:30 AM
xlt4wd90's Avatar
xlt4wd90
You can measure the ID of the holes in the timing cover for the OD of the spacer. I think you can probably turn that on a lathe; cut the outside diameter to just over your measurement, then test-fit into the hole in the cover, and cut down enough to prefect the fit. Then drill a hole through it large enough for the bolt to go through (5/16"?)
Also note that older engines did not have those locating dowels. You just aligned the bottom of the cover with the block skirt/pan rail.
Old Mar 30, 2013 | 08:41 AM
baddad457's Avatar
baddad457
The alignment dowels are pretty small, gonna be a bitch to make. It'd be easier to find a set off another motor or try a local engine building company for new ones. "Dorman" may make these, they make many of the small engine parts, bolts, nuts, fittings,etc. I may have a set I'll let you have, I'll try and look for tham later today.
Chris Gover Ford
Jun 13, 2016 11:55 PM
my93
Jan 1, 2012 08:07 PM
timboslice85
Aug 24, 2011 11:19 AM
F3fitty
May 11, 2011 10:08 PM
Supercab
Mar 23, 2006 07:08 PM
