HELP ME ZF5 Conversion
Old Mar 29, 2013 | 07:29 AM
Centurion388's Avatar
Centurion388
hey im doing a Zf5 conversion to replace my E4OD and I can't find the pedal assembly that I need that has the same mounting style that mine has for a swap here's a pic of mine.
Old Apr 4, 2013 | 06:42 AM
Centurion388
Anyone, anyone at all
Old Apr 12, 2013 | 10:06 PM
IDIDieselJohn's Avatar
IDIDieselJohn
You'll need a pedal assembly from the same generation truck you have.
So if your truck is a 1990 for example, you'll need a clutch pedal assembly from an 87-91 F-series (150, 250 or 350 makes no difference).
And if your a 92 and newer, a 92-96-97HD pedal assembly will be needed.
That shouldn't be to hard to find in a junk yard.
Old Apr 16, 2013 | 12:05 AM
Alvin in AZ's Avatar
Alvin in AZ
x2 all that. :)
Looks like the one from my '91 Bronco so, even John's example is right.
It's made from magnesium, be nice to it. ;)
The steel ones Ford used later, have a problem you'd need to fix. ;)
Don't forget to get one of these, it's a firewall re-enforcement...
(Ford part 7A621)
^^it works great! :)
Here's what the pushrod and stud looked like out of my '90 F250 parts
truck (ZF for the Bronco) and the firewall was still in "like new" condition,
no kidding...
Welded in a new stud from a grade 8 bolt (~4140) and replaced the
wimpy clutch pushrod with a brake pushrod. It needed to be shortened
and re-rounded...
To protect the magnesium frame I mounted a ~1+1/4" thick "vibration
isolator" on the floor for the lever to mash down on instead of being
stopped by the frame, you can see it there just above the emergency
brake pad...
Made a thinned-down one (used the bench grinder) for the upper stop.
Alvin in AZ
F-250 restorer
Jul 25, 2018 09:37 PM
jschluter
Feb 11, 2016 03:17 PM
Outlaw56
40
May 27, 2014 05:39 PM
grinnergetter
31
Jan 18, 2013 08:11 PM
bruce32563
Nov 10, 2008 10:01 PM
