missing part !
Old Mar 28, 2013 | 04:02 PM
460tuff's Avatar
460tuff
missing part !
anyone know where i can find the fuel adjustment screw for a holly four barrel E5HE-9510-EC list-50260-2 3405. I was told the part num. is 359747S ! I own a 1986 F-350 1ton with 460ci.
Old Mar 28, 2013 | 05:13 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The idle mixture screws are in the bottom flange of the carb.
They are covered by tamperproof plugs.
I drill a small hole in the plug and crank in a screw, then pull the plugs out with a pair of vice-grips.
A cruder method is to grind off part of the cup holding the plugs.
http://www.flemworld.com/
Old Mar 28, 2013 | 06:01 PM
460tuff's Avatar
460tuff
i have a missing part !
Thank you for your info. I guess i didnt say that i need that part ! Im unable to post a pic of the part that im missing !
Old Mar 28, 2013 | 06:29 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sorry, I thought you meant you can't find them.
That # is for a float bowl screw.
You want this, part# 16-27.
Holley Idle Mixture Screws
Says $4.95 and in stock.
Old Mar 30, 2013 | 04:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 460tuff
anyone know where i can find the fuel adjustment screw for a Holley four barrel E5HE-9510-EC list-50260-2 3405.
I was told the part number is: 359747-S2 I own a 1986 F-350 460.
359747-S2 .. Screw-Fuel Bowl & Plugs Assy to Carburetor Main Body ~ No. 12 -24 x 2.56" long / Obsolete
No Ford Dealer or obsolete parts vendor has any.
Old Mar 30, 2013 | 08:11 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I wouldn't even try to buy Holley parts through Ford. Go to Holley's website and you will just need to search for a parts breakdown. Jim is correct, the idle mixture screws on these are in the throttle body and are a real PITA to adjust. The holes in the side of the primary metering block are just the way Holley casts them. The screw NumberDummy crossed for you is a standard Holley float bowl screw, any place that carries Holley performance parts may have a pack of 4 on hand, if not they can probably order them.
Old Mar 30, 2013 | 10:23 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Don't try and use the regular 26-101 Holley part number.
The large heads won't fit in the recess.
The link I posted is the correct part.
Here on Ebay; http://www.ebay.com/itm/HOLLEY-BRASS-IDLE-MIXTURE-SCREW-KIT-CORK-AED-BG-DEMON-GRANT-QFT-CARBS-/400442819044?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d3c4081e4&vxp=mtr
Mr. Gasket (ugggh) makes them with small heads, #8318
Old Mar 31, 2013 | 11:48 PM
460tuff's Avatar
460tuff
Thank you for the information you have been very helpful !
niko20
23
Sep 1, 2019 08:44 AM
D-Rock
Jul 26, 2011 11:28 AM
bryan_johnson
Jun 26, 2007 07:24 AM
dixiemudder04
Oct 21, 2006 09:51 PM
me1mckee
Nov 22, 2004 11:21 AM
