Shortblock
Old Mar 27, 2013 | 08:29 PM
LED19's Avatar
LED19
Shortblock
Looking at a 2005 X 6L Powerstroke diesel with 146,000 miles. Had a shortblock replacement at 117,000. Would this have corrected the likely causes for future engine failure which I understand is all too common in this
engine?
Thanks.
Old Mar 27, 2013 | 08:42 PM
BLADE35's Avatar
BLADE35
That Depends the 05 might have the upgrades or might not
Why are you looking for a Shortblock
what year is it going into
More Info
Old Mar 27, 2013 | 09:01 PM
LED19's Avatar
LED19
Carfax indicates shortblock replacement at 117,000 mi in 2010. Excursion.
Old Mar 27, 2013 | 09:12 PM
BLADE35's Avatar
BLADE35
Oh so you want to Buy this X???????
Old Mar 28, 2013 | 06:29 AM
MC5C's Avatar
MC5C
It will probably have similar requirements and needs as any 6.0L PSD. If it was a short block it will have the original heads, injectors, HPOP, etc. You will need to monitor the coolant temps with a data reading gauge, monitor the FICM, basically treat it as any used engine. It might have gotten upgraded STC fitting, stand pipes and dummy plugs, it might even have head studs. But you will do what we all do to keep the engines happy, nothing changes there.
Brian
4inchlovin
Feb 4, 2010 01:18 PM
hollyf
Oct 5, 2009 07:02 PM
frogman434
Oct 21, 2008 03:20 PM
Paul Westski
May 12, 2005 03:23 PM
