Warm starting problems
Old Mar 26, 2013 | 11:32 AM
acdc's Avatar
acdc
Arrow Warm starting problems
I have a 1996 F150 4 wheel drive 5.8L
When I start it cold no problem. When I
cut it off for a short time it is hard to start
and smells like it is flooded once it starts.
It cranks and cranks before starting.
If I let it set for a while it fires right up.
Any suggestions?
Thanks
Old Mar 26, 2013 | 11:54 AM
stewart89's Avatar
stewart89
Does your truck idle nice or does it sometimes idle high? Any surging or choking?
Old Mar 26, 2013 | 12:14 PM
acdc's Avatar
acdc
None of that. This just started out of the blue.
Old Mar 26, 2013 | 12:28 PM
Truckin Bob's Avatar
Truckin Bob
Any suggestions?
Thanks
When you turn the key to run (not start), does the fuel pump run for 1-2 seconds then cut off, or, do does the fuel pump run continiously ????
Also, have you checked for any trouble codes yet.
Bob
Old Mar 26, 2013 | 12:59 PM
stewart89's Avatar
stewart89
I agree to see what codes are present.
Old Mar 26, 2013 | 01:09 PM
acdc's Avatar
acdc
I haven't checked codes yet.
Listened for fuel pump and it is doing the normal thing.
Cuts off after a couple seconds.
Old Apr 14, 2013 | 10:46 AM
acdc's Avatar
acdc
Checked codes
I checked the codes and fixed the egr code.
Fixed the O2 sensor code. Now I have no codes but still the same
problem along with high idle and rough running. HELP
Old Apr 16, 2013 | 10:14 AM
acdc's Avatar
acdc
HELP
finally got codes P0118.
Any thoughts?
444gd
May 24, 2016 10:08 AM
RevLemmon
Jan 2, 2016 05:18 PM
IDAH0.REDNECK
Feb 8, 2013 10:47 AM
1986fordrangerman
Modular V8 (4.6L, 5.4L)
Feb 21, 2009 11:13 AM
