Driver side vent
Old Mar 25, 2013 | 05:22 PM
410 Highboy's Avatar
410 Highboy
Driver side vent
The screws holding the vent cover are frozen .I have sprayed with auto trams fluid / acetone mix . It mounts emergency brake mount . Seems to be too much flex for a hand driven impact driver .
Should I go after the screws with a Dremel cut off or is there a better method ?
Old Mar 25, 2013 | 07:04 PM
redroad's Avatar
redroad
Is the fender off and visible from the outside or can you at least spray up there with buster ?
Old Mar 25, 2013 | 07:15 PM
410 Highboy
No. I am working from inside the cab.
Old Mar 25, 2013 | 07:39 PM
redroad's Avatar
redroad
I got that but my thoughts are the rust that's holding you up may be visible from between the fender and cab .. after all that's where it gets it's fresh air from .. if you can squirt some buster up in there on the end of the bolts you may have a better chance at breaking them loose
Old Mar 25, 2013 | 09:01 PM
crownver's Avatar
crownver
On my '77 F100 the air vent gets fresh air from the cowl vent. Would think yours is the same. I have that whole thing in pieces now. Don't think there's any way to reach the screws from the back side. Not sure what you mean about the emergency brake being part of it. Maybe I'm missing something. You do mean the sliding vent on the kick panel?
I'd drill the screw heads off, then when you get the vent off you should be able to grab em with vice grips.
Old Mar 25, 2013 | 09:07 PM
redroad's Avatar
redroad
your right I was thinking of this one ..Note to self don't rely on your memory so much
Old Mar 25, 2013 | 09:20 PM
crownver's Avatar
crownver
Well, that's the one I was thinking of. Mine's off right now. What did 410 Highboy mean then?
Old Mar 25, 2013 | 09:22 PM
redroad's Avatar
redroad
Drivers side but not sure after that because he said emergency brake
Old Mar 25, 2013 | 09:27 PM
410 Highboy
My mistake . Emergency brake pedal is in the way .i can't see how to access it except from the inside .I am going to try a Dremel on the inside . Leaves , debris , rust , and who knows what else I will find in there . I have two freshly painted fenders ,but I am not at that stage yet . It is a daily driver .
Old Mar 25, 2013 | 09:46 PM
jim collins's Avatar
jim collins
I removed the E-brake first for the room and then they came out easy. Mine was leaking air and i never used it anytime , so i made a cover for it to block it .
Old Mar 25, 2013 | 10:00 PM
crownver's Avatar
crownver
Yeah!?
Sillbeer
Nov 28, 2014 05:38 PM
codafisler
Apr 18, 2012 08:05 AM
AK Fifty-Three
Feb 19, 2006 10:15 AM
Franken-Truck
Apr 25, 2005 09:16 AM
1bad390
Mar 10, 2003 09:16 AM
