How Our Oil Filter Media Works (No It Doesn't Strain/Filter The Particles Out)
Seems to me what was being suggested, was that an inexpensive, poorly made, no-name filter, isn't likely to have quality components, nor have as much filter media, filter as well, nor last as long, as a better made more expensive filter by a known manufacturer, that has a reputation to up hold!!
Some $10-$15 filters will outperform some $3 filters.
This is a true statement.
Intelligent Oil Life Monitor
From a link in our "Tech Info" page atop this forum an explanation of Fords IOLM. Personalized Vehicle Owner Information
BUMP:
More oil filter design info from Machinery Lubrication for pondering. The Importance of Dirt-Holding Capacity in Oil Filters
Kinda looks like a filter media with a blend of cellulose & synthetic fiber, produce a water absorbing surface & depth loading media, whos synergistic sum result, is greater than the sum of the individuals!!!
Cellulose can absorb/remove & hold water & sludge, has a varying surface geomerty that has a lot of surface area, so sets up a lot of turbulence as the oil flows over & around its fibers pores, so can trap & hold larger particles & water, while the smaller diameter more uniform synthetic fiber media catch the finer particles for finer particle filtering & provide support strength over time, as the cellulose fibers weaken when it absorbs water or acids!!!! So the filtering ability/synergy of the Combination of both fiber types is overall greater than the ability of a filter media made exclusively of celluose or synthetic fibers alone!!!!
Wear particle Size isn't the Only thing our filter needs to remove!!!! Water & acid by-products/sludge, need to be removed & held onto, so the oil can last longer. By being able to hold onto the sludge, it isn't avaiable to hasten the oxidation/thickening breakdown of our oil, so our oil can last longer while doing a better job of preventing corrosion wear, as well as physical wear from large abrasive particles.
The filter needs to be able to do all this while providing/passing plenty of lubricant Volume, no matter the temperature/viscosity change of the oil (think cold high rpm starts), or when we get crazy & go WOT at throttle up!!!!
SO, our oil filter is plenty busy, Removing & Physically Holding Onto chemical & physically abrasive particlers over its specified change interval, while the filter media is having to endure a lot of changing oil pump vibration pulses/flexing the filter media during our filter change interval, without weakening/distorting, collapsing, or rupturing!!!!!
Choose your oil filter wisely!!!!
The filter mfgrs councils input on different types of filter media & how they do their thing to keep our air & fluids clean. A Look at Filter Media
Bump:
More info on how media filtration works & the different states of filtration that come to exist over time depending on whats being captured. https://www.machinerylubrication.com...ticles-capture
Late to this party and its a fascinating read----just wondering how the Motorcraft FL-820S filters compare in proper filtration and moisture absorption that's so important?
FWIW I DIY change oil in my 5.4 gas engines at no more than 4K miles driving, typically closer to 3K though. I do idle a bit more than most which is another factor why I change at those intervals.
I just got off the phone with an engineer at Wix and he actually laughed when I told him about the article. He stated unequivocally that the oil does, in fact, pass through the filter media for filtering as illustrated in the MANN video.
Edit: Baldwin says the same thing when I called their tech line, the oil is filtered by passing through the media.
BUMP:
More filtering info from Machinery Lubrication that might be interesting & helpful in helping getting our minds wrapped around some of the goings on inside our filtering media. Lots to think about when filtering a liquid like engine oil, in differing temps, stop & go flow, different oil & filtering medium & what happens to particles that settle out after engine shut down, or what happens to particles captured during a drive cycle under varying flow conditions & temps by different media materials. https://www.machinerylubrication.com...ticles-capture
#28
#29
There probably isn't a way to determine "the best". My untrained, uninformed opinion would be that higher flow rate would offer less filtration, better filtration would decrease the flow rate, some will trap and hold more impurities depending on filtration media and amount of material......then there has to be differences in canister burst strength, failures in the little springs, clogs, tears, valves failing....... with all of this testing.....there should be more data than opinion. But I see a lot of opinions.
#30
Personally, the "best" filter for me is a filter that protects my engine well enough to get me to 150,000-200,000 miles and costs the least.
I know that some do care, but getting my engine to last 300,000 miles is not anything that I am concerned about or willing to pay for.
