2007 axels etc under 1997 e 350
Old 03-24-2013, 04:27 PM
051's Avatar
051
051 is offline
Just in case anyone was wondering I can tell you for sure this will work. I put the entire axels, hubs, shocks, brakes etc, front and back along with the steering gear box and tie rods from a 2007 E 350 under my 1997 E 350.
Now from the frame down I have less than 100k miles on my ride and I have nice heavy disk brakes front and back.
The newer stearing gear box had bolts that were about 1/8" larger in diameter than the 1997 so I had to drill out 3 holes. Other than that everything just bolted right into place!!! My 97 rims fit right on the 07 hubs.
Both vans were single wheel, 2 wheel drive regular cargo vans, the 07 was 4.6 gas and 97 is 7.3 diesels. I did keep my front springs because I figured they were stronger for the weight of the 7.3.
Old 03-25-2013, 06:24 AM
JWA's Avatar
JWA
JWA is online now
Received 1,410 Likes on 1,112 Posts
This is good to know so thanks for posting!
I was considering swapping out my '03 front end bits for new take-off parts of a '12, told by a knowledgeable source it was a direct swap, minor differences only such as different flexible brake hoses. Radius arm brackets are a bit different but still mount to the frame exactly the same.
Thanks again!
lazyscholar
01-29-2011 10:50 AM
Brain's 97 Diesel
02-06-2010 01:04 AM
Flat8
1947 and Older Ford Trucks
01-13-2010 02:07 PM
KellySue
11-01-2006 09:46 AM
lee armistead
13
04-30-2006 11:35 AM
Quick Reply: 2007 axels etc under 1997 e 350
