Sponsored by: Real Truck
Need New Rotors
Old Mar 23, 2013 | 01:24 PM
Troobly's Avatar
Troobly
7th Gear
Need New Rotors
Still have the factory rotors on my truck which are starting to warp.
Which aftermarket rotors and pads do you guys think are the best for around 3 to 4 hundred dollar area?
I have a 2001 F250 Supercab 4X4 XLT 6.8 V10
Thanks,
Old Mar 23, 2013 | 02:43 PM
rattleNsmoke's Avatar
rattleNsmoke
Check out Rockauto Auto Parts. Inexpensive and plenty to choose from. I picked up the Raybestos slotted rotors and H\D pads last year. They are slightly noisy (squeal) when you stop but they stop on a dime. Check out the link.
www.rockauto.com
Old Mar 23, 2013 | 02:47 PM
RPM371's Avatar
RPM371
There's a lot of opinions on brakes, but I bought a full set of Powerstop. At around $125 a wheel I consider it cheap insurance.
Here's one of many threads on brakes:
https://www.ford-trucks.com/forums/1...-opinions.html
Old Mar 23, 2013 | 03:56 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
I bought Powerslots, cryoed/slotted rotors from tirerack.com, $300 for both shipped to house, and Hawk pads, 60k on them and still love them!
Old Mar 23, 2013 | 03:59 PM
PSDlongbox's Avatar
PSDlongbox
Raybestos front/rear with wagner thermoquiets. 300 bucks all in
Old Mar 24, 2013 | 07:45 AM
fmtrvt's Avatar
fmtrvt
Troobly,
They are not warping, they have worn unevenly. If the pulsation you feel is just starting without any major heat events often a change to a more rotor abrasive pad will correct this. With the ’99-‘04s, the OE friction material should have been more abrasive to not have this issue with non-commercial operated vehicles, or vehicles that run mostly on the highway.
Performance Friction “Z” pads or Hawk LTS are the best choices around this, but the Motorcraft SD pads work fine too, just not as high in friction as the others.
For rotors you just need high quality; the slots or cryo are not necessary and holes are a no-no.
The most important thing during assembly is to get the rotors installed under the factory spec of 0.0015” total runout; less is better. We probably built up over 400 rotors on SD test vehicles and only had one OE Blue Box OE rotor that ever was out of spec that could not be brought in by indexing the rotor to the hub.
snowmobile mike
Aug 19, 2016 08:09 PM
stemwill
Nov 8, 2011 08:54 PM
chazman
Jan 21, 2008 04:14 PM
little truck
Sep 2, 2003 02:25 PM
MustangGT221
May 11, 2003 09:09 PM
