Starter issue
Old Mar 21, 2013 | 08:21 PM
stonecoldmp's Avatar
stonecoldmp
Starter issue
I have a 79 ford f150 with a 302. Had to replace my starter. It started fine when I first put it on and now it whines and is grinding on my flywheel. Any ideas on what is wrong.
Old Mar 21, 2013 | 08:28 PM
fmc400's Avatar
fmc400
MSEE
Is the starter still bolted down tight? Any chance the new starter is just plain bad?
Old Mar 21, 2013 | 10:05 PM
stonecoldmp
Bolted tight and had 3 starters do same thing... Do I maybe need a shim?
Old Mar 22, 2013 | 03:50 AM
Filthy Beast's Avatar
Filthy Beast
Auto trans or stick? There could be a difference...
Old Mar 22, 2013 | 07:45 AM
Canus's Avatar
Canus
There IS a difference between the auto and manual transmission starters. One has a longer nose, but for the life of me I can't remember which is which. Old age SUCKS!!
Old Mar 22, 2013 | 08:02 AM
fmc400's Avatar
fmc400
MSEE
No shims on Ford starters.
Old Mar 22, 2013 | 08:03 AM
stonecoldmp
Auto trans
Old Mar 22, 2013 | 08:09 AM
fmc400's Avatar
fmc400
MSEE
Auto trans
He didn't mean "what transmission do you have so I can go figure this out for you," he meant "make sure the starter the parts store is giving you matches your actual transmission." In other words, you need to check with the parts store and ask them if the starter they've been giving you is indeed for an automatic transmission.
Filthy Beast
Thought there was....that 1/2 brain cell I have left doesn't kick in all the time...
Absolutely, Canus! Gettin' long in the tooth bites!
Old Mar 22, 2013 | 08:17 AM
Filthy Beast
Ha hahaha.... not to be a bunghole, but.....
Exact-a-mundo!! Thank you, kind sir, for clarifying my post....
Old Mar 22, 2013 | 08:32 AM
jim collins's Avatar
jim collins
Auto transmission for the 289 / 302 starter has a nose about 3/8" longer than the one for a standard transmission. I have a couple of each in my stash and have tried the wrong one if i never checked it close before installing . A standard one to an auto trany may start a few times until it damages the flywheel teeth , then start missing. The auto one in a standard set up will jam up most of the time and damage the flywheel and starter gear most of the time. Been there and done that more than once , some of us just never learn from our mistakes .__
Old Mar 22, 2013 | 02:42 PM
stonecoldmp
Yea I double checked and made sure it was the right starter... It looks like the tooth spacing on my starter is bigger than the tooth ratio on my flywheel.
Old Mar 22, 2013 | 03:40 PM
jim collins
If the tooth spacing is different then they sold you the wrong starter or they replaced the drive gear with the wrong one. Do you still have the old one or was it a core trade in ? Anytime they ask for a core trade on a part, i make them open up the box the new one is in so i can see it's the right one. I would take it back and tell them to get the right one.
jas88
Nov 16, 2016 07:42 PM
hwknsdrag
Feb 4, 2012 09:13 PM
dirtballer
17
Jan 3, 2009 07:04 PM
sckootter16
Oct 13, 2008 03:32 PM
marks69
Nov 10, 2006 07:06 AM
