Quick Question
Old Mar 19, 2013 | 02:53 PM
likttlegiant's Avatar
likttlegiant
Quick Question
I have a 1969 Ford F-250 Ranger with a 360 in it. It hasn't been started for 8-10 years. I replaced the battery, solenoid and spark plugs. Bought a new Air filter and oil. The front and rear differential looked good on oil. Same with the tranny and transfer case. When I try to turn it over it tries to start at first. I can hear the pump going when i turn it over. It has a little gas 1/4. If anyone can reply with some suggestions would be much appreciated thanks.
Old Mar 19, 2013 | 03:01 PM
HIO Silver's Avatar
HIO Silver
I assume you mean you can hear the fuel pump when you manually crank it over? Ya must have hearing better than a 10-point buck.
Verify spark... a blue one at that.
Verify fuel... work the throttle while looking down the carb's throat for two jets of fuel.
Even then, sitting that long prolly has dried out the carb components... the accelerator pump diaphram is notorious for drying up. My guess is that it has rotted and is causing a flooded condition.. the fuel bowl empties down the carb and into the manifold. I recommend throwing a $22 rebuild kit at it to establish a known-good condition.
Old Mar 19, 2013 | 03:06 PM
likttlegiant
I did manually crank it over with the spark plugs for 10-15 minutes. you mean just pull a plug out and see if it sparks when it contacts metal ? I'm not really mechanically inclined so what do you mean by two jets of fuel ? I can go buy a carb rebuild kit.
Old Mar 19, 2013 | 05:14 PM
HIO Silver's Avatar
HIO Silver
Remove the air filter and look down the carb as you work the throttle. Fuel should be sprayed with every action fo the throttle lever.
Pull a spark plug wire and pull back its boot. With a pair of insulated pliers, hold the conductor about 1/8-inch away from the engine block and have someone crank it. A blue spark indicates a strong spark... an orange arc would indicate that the ignition system needs to be changed.
Old Mar 19, 2013 | 07:53 PM
Redcat Diesel's Avatar
Redcat Diesel
If that noise you hear is a clicking it just might be a damaged tooth or two on the flywheel ring gear. Some fresh gas would be helpful too.
HIO silver is on the right track with the ignition issues. You might want ask your friends if any of them has experience with ignition point distributors. Having points stick closed after a decade or so isn't unusual.
Old Mar 20, 2013 | 07:55 PM
likttlegiant
Update. I got it to turn over ! I let it idle for 5 minutes, no black smoke or white smoke ! I drove it all the way to town and she is running real good. Thanks for all the suggestions.
Dane916
Feb 21, 2017 07:33 PM
1952 Ford
27
Jun 19, 2016 11:22 AM
RacingInTheStreets
Nov 12, 2012 04:10 PM
coleboy11
Dec 25, 2011 05:58 PM
nick65f100
Aug 22, 2005 11:42 PM
