I am more and more convinced that flushing the cooling system is really bad idea. All it seems to do is stir up the junk and clog the oil cooler. I haven't found any evidence that flushing a system with delta's getting marginal does anything but guarantee a new oil cooler will be installed very very soon.
I saw my delta's steadily climb at the end of last summer and into the winter. In early fall I was seeing deltas in the upper teens to 20* and spent a full day flushing and reverse flushing. Guess how many degrees I saw my delta drop.. 0*. I've heard some people say that the flush and reverse flush can help buy you some time if you get to it early enough. But once you start seeing delta's around 20* the crud in the oil cooler is probably pretty well lodged in there for good.
Just did my oil cooler R&R and EGR delete this past Friday.
Couple of thoughts:
- You don't mention EGR delete. Would be a good time to do so while you're there or if you want to keep the EGR cooler might be good to replace it with a new one.
- All of your o-rings should come with the oil cooler kit
- You'll want to get new intake manifold gaskets
Good luck! There's lots of smart guys on here so you'll have all the help you could possibly need!
I haven't had issues after just draining and filling. The chemical flushes are really only for when you are already committed to changing the oil cooler, it'll knock all the crap loose and flush it out so the new one is less likely to clog. I don't buy into the flush-and-backflush procedure as maintenance, it's for when you're actually repairing a problem.
