Please help me identify my engine!
Old Mar 19, 2013 | 12:25 AM
TucsonBogger's Avatar
TucsonBogger
I recently picked up a 74 f350 super camper special and am now rebuilding the motor, but i cant figure out the size engine is in it, i do know it is the original to the truck, a few friends have told me they think it's a 390 but i would like to know for sure before i buy new cams for it and end up with the wrong ones, does anyone know any way to determine the size?
Old Mar 19, 2013 | 12:27 AM
Jimmyrig's Avatar
Jimmyrig
How man bolts does each valve cover have? If its 7 its a 460
Old Mar 19, 2013 | 12:32 AM
Jimmyrig's Avatar
Jimmyrig
Also check the passenger side of the block for the serial# should start with something like (D1VE) and check the head#. should be something starting with like (D3VE)
Old Mar 19, 2013 | 12:35 AM
co425's Avatar
co425
Looks like the intakes under the valve cover. More than likely its a 360 FE. Only way to tell if its a 390 FE is to measure the stroke.
Old Mar 19, 2013 | 12:44 AM
TucsonBogger
its a 5 bolt valve cover, the info sheet on the door is wrong because the door has been replaced
Old Mar 19, 2013 | 12:46 AM
TucsonBogger
i tried to identify the intake manifold code, but i couldnt figure out the size using it, just that it is the original engine
Old Mar 19, 2013 | 12:52 AM
TucsonBogger
everything ive read about it says its an fe type engine
Old Mar 19, 2013 | 01:03 AM
Sooper Camper's Avatar
Sooper Camper
its an FE, there should be a block casting # on the right side under the head and behind the alternator. there is also one down by the oil pump. or you can attempt to measure the stroke of a cylinder while a spark plug is out. there is no other way as all FE blocks look essentially the same.
Old Mar 19, 2013 | 01:09 AM
TucsonBogger
i currently have the heads off, how would i go about measuring the stroke of the cylinder? sorry for sounding dumb, but this is the first time i've ever had to identify an engine
Old Mar 19, 2013 | 01:10 AM
1975MudRat's Avatar
1975MudRat
If you have 5 valve cover bolts it is some type of FE. My guess is its either a 360 or a 390.
Old Mar 19, 2013 | 01:11 AM
1975MudRat's Avatar
1975MudRat
Do you have the engine out of the truck???
Old Mar 19, 2013 | 01:14 AM
TucsonBogger
no its still in the truck, but i have the intake and heads off
Old Mar 19, 2013 | 01:18 AM
1975MudRat's Avatar
1975MudRat
Ok well to measure the stroke make sure a piston is at the bottom of the cylinder and measure from the piston to the to the top of the block. That will give us a number that we can tell you what motor it is. Also you should measure the bore, just put a tape measure across the tho cylinder bore and give us then number.
Old Mar 19, 2013 | 01:19 AM
Sooper Camper
then crank the engine over by hand and measure how far up and down the piston slides. google is your friend. i think a 390 has ~3.75" stroke and a 360 is ~3.5". its all on the web, really easy to find.
Old Mar 19, 2013 | 01:28 AM
1975MudRat's Avatar
1975MudRat
Actually a 390 has a bore of 4.05 inches and stroke of 3.785 inches and the 360 has the bore of a 390 4.05 inches and used the 352s bore of 3.5 inches.
