back in a ford again
Old Mar 18, 2013 | 07:13 PM
CLR f-150's Avatar
CLR f-150
well guys after a couple years with my old jeep, my dad decided that he wanted me to get something a little newer. so after a couple of weeks of looking at trucks we settled on a 95 f-150 short bed regular cab 5 speed straight 6 4x4. we went and looked at it and after a week of thinking about it we decided to get it. I like the truck but it needs some work. just a bunch of little things nothing major. im just going through it and gonna do a oil change, air filter , fuel filter you know stuff that people would normally do if they thought about it lol. so anyway it needs a key lock cylinder which I bought and need to install. the windshield wipers work but only on low and high no delay and I hear like sparking or something going on there. the lights all work but seems to be loose in the contacts, is the light switch wore out ?. more updates as I get to look at the truck more, thanks for the info guys and ill have some pics up to
Old Mar 18, 2013 | 07:36 PM
CLR f-150's Avatar
CLR f-150
Old Mar 18, 2013 | 07:57 PM
kermmydog's Avatar
kermmydog
Nice truck. I can't help you much I have a washer issue on my 95. My 86 Ford had headlite switch issues. I replaced the switch three times in 15 years. So you could have a bad switch.
Craig
Old Mar 18, 2013 | 08:13 PM
buzzy613's Avatar
buzzy613
love the color that's an awesome truck!
Old Mar 19, 2013 | 02:15 PM
CLR f-150's Avatar
CLR f-150
Yeah I like the truck, paid 1600 delivered with gas to lol. Just got some tinkering to do
Old Mar 19, 2013 | 03:01 PM
blue924.9's Avatar
blue924.9
what do you mean by connection seems loose. on my 92 if you have to pull it out all the way and push it in a little for the interior lights to come on with the headlights.
Old Mar 19, 2013 | 03:36 PM
CLR f-150's Avatar
CLR f-150
When you turn the **** to adjust the brightness it don't have good contact cause half the time the lights go out when you adjust it
Old Mar 19, 2013 | 06:57 PM
Phy's Avatar
Phy
Sounds like a bad headlight switch. If you take the switch out, look at the electrical connector. If it looks like it's been hot, replace it. That's a common problem, and new connectors are available at the auto parts stores...
Old Mar 20, 2013 | 05:30 AM
CLR f-150's Avatar
CLR f-150
Alright I'll give that a try and see what I find, where is the wiper delay box found ?
Old Mar 20, 2013 | 08:40 AM
Jaime74656's Avatar
Jaime74656
should be on the passenger side just by the door, just need to remove the kick panel (name?) and it should be there.
Old Mar 20, 2013 | 03:30 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Sharp lookin truck! My trucks twin!
Mines a 1994 4x4 5 speed straight 6 shorty! With a 1990 front clip tho
Old Mar 20, 2013 | 03:35 PM
CLR f-150's Avatar
CLR f-150
Cool looking truck I also like the look of the 90 nose as well maybe I'll consider it lol
Old Mar 20, 2013 | 06:57 PM
m350's Avatar
m350
CLR f-150 is my son,,we spent about an hour and ten minutes in DMV today he got the F-150 Registered this afternoon, prior to that this morning he replaced the Ignition switch, that was the source of several of the trucks electrical issues, also intalled Bosch Icon wiper blades, then he changed the oil/filter after his maiden voyage around town with his truck,,,What a Nice little truck it is,,amazing to me how the 4.9L pulls the hills around here with the 3:08 gears and the 5-speed, truck rides nice too,, we Did Good !
Old Mar 20, 2013 | 08:30 PM
CLR f-150's Avatar
CLR f-150
Well I had a good run up to my gf house truck did great just need to replace the bad radius arm bushing or should I say no bushing lol, lights worked good and had no issues heat worked pretty good and starts right up. Gonna look at the trans fluid and other stuff soon.
Old Mar 21, 2013 | 07:54 PM
CLR f-150's Avatar
CLR f-150
Well today I changed the radius arm bushings, but after taking the rest of it apart it badly needed a shock tower and a shock. After about 7 hours I got it all back together and it looks great I'll get som pics up soon it's to dark now
