front driveshaft with d60 swap
On my 78 f150 4x4 Scab: I'm installing the Dana 60's I recently bought and have run into a small hickup, which I can fix but I was wondering about.
Truck originally had a d44 up front. Apparently the front driveshaft on the d44 is about 1 1/2" longer than the one that came with the d60. So, I'm going to swap them to solve that issue.
Now, when I put a 6" lift on the truck later, I will have to have a longer d/s on the front correct? Will the 1 1/2" longer one be long enough to take care of that issue? I kinda remember reading you have to add 2" to the d/s but can't remember. Anyone done the swap then lifted later? I'll try to get a side by side in a bit when I get the long one out.
There were different yoke options .. Here is a great resource for your axle
http://www.pirate4x4.com/tech/billav...ice_manual.pdf
Pirate4x4.Com - Extreme Four Wheel Drive
How are you running a CV drive shaft in the front? Using degree shims or clocking your spring pads in the front screws up your caster angle. I'm not saying it can't be done but I would figure this would be a no no for the street. The only way I know of to properly do this is to re weld your outer C's to the right angle while tipping your yoke up to point at your transfer case yoke. I'm real curious since I have a cv shaft in the rear and since I'm doing a 60 front swap too. I would love to have a cv shaft there as well.
giorgio.fo
03-02-2016 10:53 AM
Backwoods351
1983 - 2012 Ranger & B-Series
12-18-2014 07:54 AM
88gtblack
06-05-2013 06:18 PM
