So, I ordered this
Old Mar 17, 2013 | 08:20 AM
Talyn's Avatar
Talyn
So, I ordered this
International 7.3L Water Pump (OE# 1831676C92, YC3Z-8501AARM, 1823669C92)
Stay tuned for updates and thoughts.
I think this is the same one Glenn bought too.
Old Mar 17, 2013 | 02:43 PM
richdawg's Avatar
richdawg
Good on ya !! ---------Nice choice and it takes care of the coolant filter dilemma, on where to put it. I'll be waiting to see how it goes A good write up of the install with pics would be excelent
Old Mar 17, 2013 | 03:08 PM
Got4wd's Avatar
Got4wd
Make sure you replace the drain seal before you put it in.
Old Mar 17, 2013 | 03:23 PM
Talyn's Avatar
Talyn
Shoudln't have to on a new one?
Old Mar 17, 2013 | 03:24 PM
Talyn's Avatar
Talyn
Yeah, my bypass leaks like a beotch.
Gotta get that thing outa there.
Bills hooking me up with a radiator and axle. So I'll go get those next month.
Be back rocking again.
When the pump gets here, the oil cooler is getting redone also.
I'll be sure to write something up or do a video.
Old Mar 17, 2013 | 09:44 PM
stainlessstroker95's Avatar
stainlessstroker95
Nice find william. Reps sent. Looking forward to the video.
Old Mar 17, 2013 | 11:24 PM
ReBilld's Avatar
ReBilld
I started to do a coolant filter a while back, but I decided to wait and do one of these pumps instead. Are the filters readily available for them or do they have to be ordered, and how often should you change them?
Old Mar 17, 2013 | 11:29 PM
Got4wd's Avatar
Got4wd
Ya but for some reason they leak with the stock ones. Do some reading on it it's been discussed. Replace it with the Viton -205 one. Mine started to leak after 5 months. Wasn't happy about pulling it again.
Old Mar 17, 2013 | 11:44 PM
oldbird1965's Avatar
oldbird1965
Actually I got mine at Bus Depot. Yes, change the O ring. These are the three threads I used for info.
Int'l water pump w/ filter...installed - PowerStrokeNation : Ford Powerstroke Diesel Forum
https://www.ford-trucks.com/forums/1...ater-pump.html
https://www.ford-trucks.com/forums/1...-filter-3.html
Old Mar 18, 2013 | 07:50 AM
Talyn's Avatar
Talyn
Originally Posted by oldbird1965
Thanks glenn, that will make things easier.
I might have some fun getting that lower radiator hose though.
Different radiator. haha.
Old Mar 18, 2013 | 09:09 AM
oldbird1965
I'm not sure what radiator your getting but the SD guys didn't have any luck with the, excuse my language, the cummings lower radiator hose. It fit good for me.
Old Mar 18, 2013 | 09:11 AM
Talyn's Avatar
Talyn
96 and 97 radiator are different from 94-95 radiator.
Old Mar 18, 2013 | 12:58 PM
LeoJr's Avatar
LeoJr
I almost did the filter on the water pump swap but didn't want to rig a lower hose together that I couldn't readily source again if it failed. I'll be watching to see how y'all solve this.
Thanks for sharing!
Old Mar 18, 2013 | 01:25 PM
Talyn's Avatar
Talyn
Thanks for sharing!
Glenn had no issues with his. I'ma have to figure mine out.
There is a dodge lower radiator hose that works perfect.
My radiator is a bit different, so I"m not sure whats up yet.
Old Mar 19, 2013 | 05:14 AM
dizzyfingers03's Avatar
dizzyfingers03
Interesting. I will have to see how that goes.
