update on my crew cab
Old Mar 16, 2013 | 11:40 PM
houstone003's Avatar
houstone003
still havent dropped the front but will do so very soon....flip kit in the rear & 5% tint all around...comments welcome
Old Mar 16, 2013 | 11:46 PM
fordman67's Avatar
fordman67
how do you plan to drop the front? I didnt know anyone made beams for these.
Old Mar 16, 2013 | 11:48 PM
ReBilld's Avatar
ReBilld
I love the look of a dually when they ride low like that!
Old Mar 16, 2013 | 11:51 PM
fordman67's Avatar
fordman67
^^^what he said!!!
Old Mar 17, 2013 | 12:03 AM
houstone003
i have an extra set of stock springs im gonna try and trim and bend so they sit it he same location about 1.5 turns if it doesnt work out ill be ordering 3" djm i beams next month
Old Mar 17, 2013 | 12:10 AM
fordman67's Avatar
fordman67
better order the beams.not supposed to bend these latemodel axles.
Old Mar 17, 2013 | 12:12 AM
houstone003
not bending the beams, the springs, if you see, the top mount it has a slight curve and mounts with a bracket i wanna keep that same setup but just 1.5 turns shorter
Old Mar 17, 2013 | 07:48 AM
fordpride's Avatar
fordpride
They make em
I Beams,dropped
Old Mar 17, 2013 | 04:48 PM
houstone003
Originally Posted by fordpride
They make em
I Beams,dropped
yeah djm makes a set they run about 650$
Old Mar 17, 2013 | 05:14 PM
fordman67's Avatar
fordman67
the geometry of twin Is will make the camber so negative I doubt there is a camber slug that will help get it anywhere in the ballpark. Good luck.
Old Mar 17, 2013 | 06:04 PM
fordpride's Avatar
fordpride
The beams are set to where your normal slugs will work.
I've used there kit on a ranger that I had
Old Mar 17, 2013 | 08:19 PM
fordman67's Avatar
fordman67
I meant stock beams with cut springs.I would figure any drop beam would have some way to adj. thats mandatory.
Old Mar 17, 2013 | 08:41 PM
fordpride's Avatar
fordpride
aaaaaah I gotcha
64highboy
British Columbia
May 23, 2016 07:11 PM
Mixer man
13
May 8, 2016 07:50 PM
bjmayberry2
May 7, 2015 10:27 PM
kashmcoll
Sep 13, 2010 03:19 PM
reamer
Mar 22, 2006 07:42 AM
