ignition problems
Old Mar 16, 2013 | 12:37 PM
'70 ford f250's Avatar
'70 ford f250
ignition problems
I have a 1970 F250, and it has a problem with starting. When I start it, seems like every other time I try, it will not start. It sounds like it trys to turn over, but then eventually when the key gets turned, it only makes a clicking noise, and it seems like the battery goes dead, but all electronics work. Im new with classic trucks, so i dont know much bout them. Im not sure if i should get a new battery or if it is something with the starter. need help!
Old Mar 17, 2013 | 09:22 AM
Alex from GA's Avatar
Alex from GA
Hook jumper cables to it and if it turns over fast the battery is probably bad. Remove the starter and take it to be tested. Change the solenoid on the passenger side inner fender. The ignition switch may be bad.
Old Mar 17, 2013 | 09:23 AM
Alex from GA
I forgot to add battery connections must be really good.
Old Mar 17, 2013 | 08:05 PM
rustywheel68's Avatar
rustywheel68
clicking solenoid but no crank - low voltage.
clean connections and check battery voltage. no need to look at the starter/ignition switch/relay at this point.
Old Mar 17, 2013 | 11:37 PM
70-360fe's Avatar
70-360fe
Also make sure your bat. cables and terminal ends are in good shape. May look good till you look closely at them. If that checks out ok I would look at ignition switch and see if you have round terminal original switch. If so might need to replace it.
Old Mar 18, 2013 | 02:08 AM
Cracker289's Avatar
Cracker289
I agree with the people who say battery connections, I have had this problem a couple of times, usually after sitting for a while, and what I usually find is that cleaning the battery connections solves the problem.
Old Mar 18, 2013 | 09:20 AM
sweetlou1's Avatar
sweetlou1
Also could have a drain somewhere which is giving you a dead battery every couple of days.
rustygold1
Jul 21, 2013 12:06 AM
vegatyme
Jun 25, 2008 11:14 AM
brocobilliam
1978 - 1996 Big Bronco
Jan 2, 2006 01:47 PM
podman152
Nov 29, 2004 06:57 AM
tealboy1
Oct 10, 2004 06:42 PM
