1999 2.5 engine question
Old Mar 12, 2013 | 08:22 PM
sawz5's Avatar
sawz5
Can someone tell me if you can replace a hydraulic lifter or
A valve spring without removing the camshaft?
Old Mar 12, 2013 | 11:11 PM
nlassley's Avatar
nlassley
You need to remove the cam followers to get to them.
/watch?v=f4rCXsDDZKg
Old Mar 13, 2013 | 07:58 AM
tomw's Avatar
tomw
Yes, the lifters can be replaced without removing the camshaft. You need to compress the lifter by bleeding the oil out, for extra clearance. Then you depress the valve spring a bit, and you can manipulate the follower out, then you can pull the lifter out of its bore.
Be careful of sharp edges when messing around there as the corners are not rounded at all and will slice fingers easily, especially when you have to use a lever to depress the valve a little for clearance. Things will just 'move' different from what you expect, and fingers will slip where they should not.
tom
Old Mar 13, 2013 | 05:24 PM
sawz5's Avatar
sawz5
Thanks tome and nlassley I guess maybe I will try to do this job
Myself as soon as I can get this John deere tractor that I'm currently overhauling
finnished. Thanks again guys rick
BroncoBilli
Dec 17, 2017 04:18 PM
79fordrat
Jun 17, 2014 02:38 PM
john smith jr
13
Oct 4, 2010 02:35 PM
91lxstang
4 Cylinder Engines
Mar 5, 2004 02:26 PM
jthompson
Jun 28, 2000 07:01 AM
