1987-1996 OBS Truck Mods (NON-Engine/Drivetrain Related)
#31
As for the overhead console, you need a temperature sensor from the Explorer as well. Then, if I'm remembering correctly, you run wires from the console to the sensor that you bought, then there is a 12V power that comes on when the key is switched to on, a ground, and *possibly* a 12 constant power. I don't quiet remember.
#32
Second, I picked up the heatshrink and necessary connectors to wire in the fuseblock.
Third, while I agree you make some awesome looking trucks, I don't believe your bereavements are necessary.
#33
To change the color of the gauges you have to remove the cluster, scrape the green film off the gauge faces from behind, then put the new bulbs in.
#35
First off, a lil grammar would not kill you. I assure you of that much.
Grammer? Did I spell something wrong or use a word incorrectly? Didn't think so.
So you have a waterproof fuse panel? That you are now wiring your setup a SECOND time?
Why would I care what you think? It looks like everything you do is half a s s e d.
#37
But, of course your mind is too busy going into full on "Degradation Mode" for you to have realized I mentioned what sort of Fuse Panel I was using, wayyyy back on Post #17.
If I honestly didn't like someone, or the stuff they do THAT badly, I'd simply move along...Jesus H. Christ this is getting out of hand.
#38
If you MUST know Brad, it's a Fuse Block out of a Ranger, the engine bay one..
#41
the words of a man who is running out of things to say. if you dont care then i assume you wont say anything else lol
#42
I redid my wiring, tidied it all up, just needs some split loom and it's all finished. And yes, it has fuses wired in.
My time, my dollar, and no one should complain otherwise.
I will give you the point you were right, and I corrected my mistakes.
But on the other hand, I think a simple PM woulda sufficed, in favor of the myriad of BS that's cluttered this thread up.
#43
Here's the Fuse Block so far, without the Panel Cover installed yet.
Split Loom and some more wire hangers will make it all nicer/neater on the eyes.
#44
Just sick of beating my head against the wall. I hope all your junk burns to the ground from INFERIOR builds
