Differential Covers
Old Mar 12, 2013 | 08:20 PM
Snowseeker's Avatar
Snowseeker
According to the Scheduled Maintenance Guide that came with my Ford F350 7.3L Diesel:
"Rear axles and power take off (PTO) units containing synthetic lubricant and light duty trucks equipped with Ford-design axles are lubricated for life. These lubricants are not to be checked or changed unless a leak is suspected, service is required or the axle assembly has been submerged in water"
Old Mar 12, 2013 | 08:32 PM
KH85's Avatar
KH85
I figured you had some proof!.....that just seems odd to me.
Old Mar 12, 2013 | 09:07 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I went with the 08 aluminum cover after reading for a week on extra capacity, drain plugs and dip sticks. Just couldn't justify the price for something I would only touch every 5 years or so. Painted the aluminum cover a nice color and putting it on this week. Painted the Dana 50 to match up front.
Old Mar 12, 2013 | 10:46 PM
KH85's Avatar
KH85
So I gotta ask whats the advantage of the '08 aluminum diff cover?? Does the aluminum keep it cooler? Drain/fill plugs?
Old Mar 12, 2013 | 11:38 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
It looks COOL. and it is cheap.
Old Mar 13, 2013 | 01:35 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
It has cooling fins on it, it is lighter than the steel one, it won't rust, and as mentioned above it is low cost.
Old Mar 13, 2013 | 05:51 AM
trekbasso's Avatar
trekbasso
Plus being cast aluminum much stiffer and less chance of leaking.
But I went for the cooler look.
Really no need to ever check level, if it leaks you will know it.
Old Mar 13, 2013 | 07:22 AM
Boom48's Avatar
Boom48
an 08 cover wont fit on my 2000 but i appreciate all the answers you guys have given lol.
Old Mar 13, 2013 | 07:24 AM
Snowseeker's Avatar
Snowseeker
Yeah, no rust! My original got hit by something and had a slight leak at the bottom. I could have taken it off, straitened it, and reused it but I already ordered and had the aluminum one. My original cover went on our 94.5 IDI 7.3 work truck.
An FYI painting aluminum reduces its cooling ability. It puts a barrier between the metal and air.
Old Mar 13, 2013 | 09:57 AM
honeydew's Avatar
honeydew
Can you say whether the Al cover is anozided? I'd guess that it is and if so shouldn't need paint for corrosion protection either.
Old Mar 13, 2013 | 11:15 AM
truckeemtnfords
No, it is not anodized, raw aluminum.
Old Mar 13, 2013 | 05:10 PM
KH85's Avatar
KH85
Any links to where to get on '08 cover? Or do you just go to the stealership? Id like to see what they look like since they are soooo cool looking!!
Old Mar 13, 2013 | 05:16 PM
  #28
honeydew's Avatar
honeydew
It's $45 from Tousley
2008 FORD F-250 SUPER DUTY Parts - Tousley Ford Parts Depot
  #29
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Ford Rear Differential Cover 12-10.25, 12-10.5 at DieselManor
Try this for a photo. I bought the bolts from my local home improvement store for about $12.
Old Mar 13, 2013 | 05:23 PM
  #30
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Why won't it fit? If you have a 10.25 or 10.5 rear end it will fit.
