Vin decoding?
Old Mar 10, 2013 | 08:19 PM
6cannons's Avatar
6cannons
Vin decoding?
Trying to decode vin on my 66
Everywhere says not valid?
Vin is f10bc748107
Old Mar 10, 2013 | 10:46 PM
6cannons's Avatar
6cannons
found what i needed
just had to ask at the right place
Old Mar 11, 2013 | 01:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 6cannons
Trying to decode VIN on my 66. Everywhere says not valid? F10BC748107
F10 = F100 2WD
B = 300 1V I-6.
C = Oakville Ontario Canada Truck Assembly Plant.
748107 = 1966, assembled September 1965.
Automakere went to 17 digit VIN's in 1980/81. Some online decoders do not recognize 11 digit VIN's.
Old Mar 11, 2013 | 07:21 AM
6cannons's Avatar
6cannons
thanks numberdummie i found the tag on the door
is beat up bad i can make out the raised numbers lust not what they mean
they are in this order
any help would be awsome
129 jh e b1 f ab
5000 150 3600 b7
i just bougt the truck two weeks ago and im tring to learn all i can about it
before i start work on it
Old Mar 11, 2013 | 07:47 AM
NumberDummy
I found the tag on the door, it's beat up bad. I can make out the raised numbers, just not what they mean.
Identified them for you.
W.B. 129 / COLOR: JH / MODEL: F100 / BODY: E81 / TRANS: F / AXLE: A8 / MAX GVWR LBS: 5000 / CERT NET HP: 150 / RPM: 3600 / DSO: B7
129" Wheelbase.
JH: J = Rangoon Red / H = Sahara Beige.
F100 2WD, 5,000 lbs. GVWR
E81: E = Red Crush Vinyl & Red Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
F = Borg Warner T-18 4 Speed Manual Transmission.
A8 = Dana 44 Rear Axle / 3.54-1 / Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
150 net HP @ 3,600 RPM
B7 = Ford Motor Co. of Canada Ltd., Pacific Lincoln-Mercury District Sales Office, where the original selling dealer ordered the truck from.
You omitted the MODEL code, I added it based on the GVWR
Purplepills
Sep 17, 2015 11:15 AM
lonewolfjb1
Large Truck
May 8, 2015 07:15 AM
gangstakr
Dec 13, 2014 12:47 PM
dllt
Apr 30, 2013 01:53 AM
bluecrowbar
Mar 2, 2006 06:43 PM
