air filter
Old Mar 10, 2013 | 02:15 PM
breedo99's Avatar
breedo99
air filter
got a 1976 ford f100 with a 360. it has the old style air filter and intake thing that has oil in it. i want to get an oil-less one. can i just clean out the old one and put a regular filter in it? or is there an aftermarket air intake i need to run? whats the best option?
why did they use oil back then in the first place....this was my first experience with it
Old Mar 10, 2013 | 03:58 PM
fmc400's Avatar
fmc400
MSEE
The "oil bath" filter was well-suited for extremely dusty areas and was an option for these trucks. If you want to go to the traditional dry type, you'll need to change out the air cleaner entirely. You can use a factory-style unit with a snorkel, or an open-element aftermarket unit. I'm not sure if anything else needs to be changed or not.
Old Mar 10, 2013 | 04:54 PM
montana_highboy's Avatar
montana_highboy
I'd recommend just ditching the whole setup, those oem style snorkel housings are very restrictive.
An internal combustion engine is nothing but a big air pump, more air in, more air out.
Replace it with an aftermarket 3x14 open air housing and K&N filter.
Old Mar 10, 2013 | 09:13 PM
breedo99's Avatar
breedo99
any clue where to find the air housing?
Old Mar 10, 2013 | 09:26 PM
JWC 3's Avatar
JWC 3
I have an Edelbrock air cleaner assy. on my 78 . Bolt on assy . Easy. Unless you are looking for stock . But stock can be found at salvage yards , and on line .
Old Mar 10, 2013 | 09:36 PM
breedo99's Avatar
breedo99
Edelbrock Universal Air Cleaner Assembly - JCWhitney
^^ will that work?
Old Mar 10, 2013 | 09:45 PM
JWC 3's Avatar
JWC 3
Well , if you like it and the $$ , It will probably work . Mine looks more like the Mr. Gasket one but is Edelbrock . Got it at O'reiley's for about $30. with filter . Mine is chrome thin steel .That one is a bit different, looks like a K&N type filter with it . But it should work .
Old Mar 10, 2013 | 09:47 PM
breedo99's Avatar
breedo99
it is expensive but im partial to black
Old Mar 10, 2013 | 09:58 PM
JWC 3's Avatar
JWC 3
Buy a cheep one and black it out . Heck , In the 80's I blacked out a CB750 . Tore it down , flat blacked everything . The exaust was the only tricky part . Got a 4-1 header with muffler that was all black . $$ If I still had it I'd post some pics . Kids took priority Now , my 75 Cb is in the barn , just waiting
Batman7777
May 9, 2018 09:38 AM
Mike-fire32
401, 477, & 534 SD Engines
Jun 6, 2011 12:12 AM
SpeedRebel09
Jul 2, 2008 08:00 PM
bchunter
17
Nov 10, 2004 09:21 AM
greenhornet
May 17, 2003 08:56 AM
