1995 f150 351 gears
What is the axle code on your driver's side door VIN sticker? Find that and we'll be able to tell you exactly what gearing is in your truck.
My '94 F150 4x4 351 has 3.55 gearing which has an axle code of 19. This may be different gearing than yours.
I would say that 3.73 gearing would be good with 33" tires and 4.10/ 4.11 gearing would be good with 35" tires with out totally wrecking your mileage.
I would like to go with 35s but i don't want the tires to be to big its only a 4" lift, on that note what would you recommend for either 33s or 35s I've seen the other post of 3.73, and 4.10/4.11, but i have also seen people post that you wont see a difference between a 3.55 to a 3.73 or even 4.10 with tire change
LipRipper3006
01-07-2017 07:32 AM
moose94
08-27-2003 11:27 AM
superaxeman
12-05-2000 12:12 AM
