Lowering Springs?
Old Jun 1, 2003 | 06:03 PM
67Ford351w's Avatar
67Ford351w
Lowering Springs?
I am looking into swaping out my cut stock springs for lowered springs, but i haven't found any companies that sell them. Any suggestions?
Old Jun 1, 2003 | 10:11 PM
CACWBY's Avatar
CACWBY
Lowering Springs?
There are several that do this, one is in KS I believe called Custom Coil Springs-I've seen in *** also. I've done this Twice, last time with Progressive Rate- they get stiffer as they compress. You will give your self negative camber, OK if keeping stock beams, it can be corrected. If also going to lowered beams-it can't be. Aftermarket beams are just welded up metal shapes and bending will probably break or at least stress the welds.
