Transmission leak
Old 01-03-2013, 04:07 PM
chaser1602's Avatar
chaser1602
chaser1602 is offline
Transmission leak
2000 f150 2wd. Drained and replaced trans fluid and filter few years ago and used the cork gasket in the filter kit. It leaked. Replaced it with another cork gasket and used silicone that time. Still leaked. Replaced 2nd gasket with the reusable oem gasket. Its leaking. Bolts have been torqued to whatever the manual says. What can I do about this
Old 01-03-2013, 04:36 PM
vaper's Avatar
vaper
vaper is offline
If you are sure it is the pan leaking my guess is the pan is bent.
Take a straight edge and check the mating surface,straighten any low/high spots.
good luck
Old 01-03-2013, 06:16 PM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
Sometimes the seals from the shifter shaft and other attached pieces can leak and run along the pan giving false impressions.
Old 01-03-2013, 06:29 PM
chaser1602's Avatar
chaser1602
I cant imagine it being bent. Not like I have abuse it. And shifter shaft is not leaking. It's dry around it
Old 01-03-2013, 06:35 PM
vaper's Avatar
vaper
vaper is offline
Doesn't take much,even prying it off a bit with a screw driver will do it.
Old 01-03-2013, 07:06 PM
vfast's Avatar
vfast
vfast is offline
take sandpaper and ruff up the area for the gasket on a flat surface...get a gasket from ford it doesn't need prematex it had ridges in it and it reuseable
Old 01-03-2013, 07:07 PM
vfast's Avatar
vfast
vfast is offline
the cork gaskets will soak up fluid and leak
Old 01-03-2013, 09:12 PM
pdqford's Avatar
pdqford
pdqford is offline
If some of the pan bolts have been overtightened, the bolt head may have dimpled the area around the bolt hole. If so, with the pan off, try putting a block of wood under each bolt hole in the pan and tapping the dimple down with a small hammer. (The bolts will pull a dimple tight up againt the mating surface, but the gasket between dimples will not have sufficent pressure to prevent leaks.)
Old 01-04-2013, 01:27 PM
coolray's Avatar
coolray
coolray is offline
I've had the o-ring on the fill/dip stick go back on one.
Old 01-04-2013, 01:42 PM
monkeyspain's Avatar
monkeyspain
monkeyspain is offline
I know that you have prob already done this but double checking the obvious. Make sure that you have scraped all of the old gasket and permatex off the pan as well as the case. an old fashioned scaping can prevent alot of probs
Old 01-04-2013, 05:10 PM
chaser1602's Avatar
chaser1602
I haven't been able to go look, but I had to tighten up the fitting for the cooler line not long ago. Gotta do that, probly time to replace it
Old 03-06-2013, 08:19 PM
chaser1602's Avatar
chaser1602
Update
With the weather permitting got a little more accomplished. It is dry around the cooler lines. Took a hammer and punch and went along the edge of the pan, cleaned it up foe a test drive. Looked like it was leaking around the speed sense so the orings got replaced. Just did that 2 days ago. So cleaned it up again and have to wait for another good day of weather. If it isn't the orings the next thing is going to be the tailshaft housing gasket
Tyler.172
04-23-2014 04:57 PM
77mud
1997 - 2003 F150
01-27-2013 08:11 PM
Stroked Out!
09-12-2009 09:42 AM
tommyboyrn
1983 - 2012 Ranger & B-Series
01-29-2007 07:44 PM
54Guy
1978 - 1996 Big Bronco
09-24-2003 10:40 PM
Quick Reply: Transmission leak
