M5OD Failure
Old Jun 1, 2003 | 05:21 PM
mdvdsn's Avatar
mdvdsn
Angry M5OD Failure
I have an 88 F250 with 5.0L engine and M5OD trannie. Truck has 203000 miles and I am experiencing my 3rd transmission failure. In all three cases I lost the input shaft and bearing. Is there a heavier duty transmission that I can use to replace the M5OD and that will be a straight forward proposition to install: ie, no major modifications involved?
Old Jun 1, 2003 | 06:18 PM
MustangGT221's Avatar
MustangGT221
M5OD Failure
Are you 100% sure its an M5OD? ZF 5 speed will bolt to your engine but will need driveshaft modification and would need to move the crossmember.
Old Jun 1, 2003 | 09:50 PM
mdvdsn's Avatar
mdvdsn
M5OD Failure
Yes, it is definitely the M5OD. How hard are these ZF 5 speeds to get ahold of?
Old Jun 1, 2003 | 10:39 PM
Racerguy's Avatar
Racerguy
M5OD Failure
Any 87- 96 (or there abouts) F250 with a 300 or 351 will have everything you need to do the swap. The 300s and 351s in F250s used the ZF, the 302 used the M5OD. If you can find a donor truck at a wrecking yard that would be the easiest. Everything will bolt in.
just-n-time
Feb 15, 2009 09:07 PM
GHog
30
Nov 10, 2005 08:35 AM
madman666
Feb 16, 2002 03:32 PM
adelyser
Oil & Lubrication
Jan 29, 2002 04:52 AM
