Problem with Hazards
Old Mar 4, 2013 | 06:34 PM
Swippe's Avatar
Swippe
i have a 97 Expedtion hazards not working ... checked fuses 23 and 27 from what i have read and both good ... not getting power on fuse 27 with key on. when i turn on my hazards i hear 1 click from relay but it don't pulse like it should .. tryed replacing Multi-Fuction swich same problems. tryed relay .. same problems wire harness to mulit-fuction switch i get 2 power readings on part of harness for turn / hazards one is just below 6 volts other is 12 volts
checked relay for turn / hazards .. get 12 volts on all 4 wires when i use turn indicator and ground on black wire ... when i use hazards i get 12 volts on 3 wires and ground on black and white with black stipe or center wire
leardvr
Electrical Systems/Wiring
Jan 2, 2017 03:37 PM
Ford'05HG
Dec 1, 2012 09:05 PM
nickp1362
Feb 5, 2010 07:44 AM
RFD_Truckie
Jul 10, 2009 06:00 PM
MustangMatt96GT
Dec 26, 2008 11:46 AM
