Australia Chapter Join Chapter , Leader: OPEN
Need help
Old Mar 4, 2013 | 04:20 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Need help
Anyone got a spare alternator I can borrow while I source a new one from the States.
Old Mar 5, 2013 | 01:04 AM
wallsy's Avatar
wallsy
Wish I had a spare I could give you mate, but I don't unfortunately. Sorry.
Old Mar 5, 2013 | 04:10 AM
aussie_f350's Avatar
aussie_f350
yeah mate, pm me your address i get it out tomoro, bit different than a stock one tho???
Old Mar 5, 2013 | 04:13 AM
SSSimon's Avatar
SSSimon
Brian, is it worth getting the local auto-electrician to see if he can squeeze some more life out of it while you're waiting for a replacement to arrive from the US?
Otherwise, on the battery charger every night and avoid night time driving till the new one restores normality.
Old Mar 5, 2013 | 06:07 AM
ChunderDownUnder
Nah. had mine checked and its fried. Run it for 30 seconds on its to hot to touch. $449 for a new one. What a wanka. Just couldnt wait so i found one on ebay (200amp) for 170 USD + 45USD for shipping. Thanks for the offers boys. Good to see FTE to the rescue.
Old Mar 5, 2013 | 11:26 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
On the alternator front,
Is it hot after sitting for a while as well? (usually a shorted diode)
Have you done an output test? (it is usually the regulator that dies, not the alternator)
Old Mar 6, 2013 | 03:35 AM
ChunderDownUnder
took it to a sparkie and he tested it. Not worth getting it fixed here cause for less I can get a 200amp. I run a third battery in the rear for camping so the extra GG's will help.
Old Mar 6, 2013 | 08:28 PM
BigF350's Avatar
BigF350
FTE Emeritus
Yeah, that's usually the way. Are you getting the Ambo unit, or an aftermarket one?
Old Mar 7, 2013 | 12:32 AM
ChunderDownUnder
this one
eBay Australia: Buy new & used fashion, electronics & home d
Old Mar 7, 2013 | 02:37 AM
BigF350's Avatar
BigF350
FTE Emeritus
Looks like a replica of the ambo alternator, very good unit, and has an external regulator so if it fails, rebuilding it is much cheaper. When I worked at FoMoCo, the parts price for a genuine unit was $6k...
Old Mar 7, 2013 | 03:36 AM
SSSimon's Avatar
SSSimon
Nice one Brian - flea-bay to the rescue!
Old Mar 7, 2013 | 04:16 AM
ChunderDownUnder
U have to be kidding ???
Old Mar 7, 2013 | 05:11 AM
SSSimon's Avatar
SSSimon
That must be $6k with engine attached, maybe?
It'd be cheaper to fly to the US, buy one at AutoCo, and fly back - 1st class!
Not exactly going to attract any 'word of mouth' customers is it!
Old Mar 7, 2013 | 04:50 PM
Diesel Submariner's Avatar
Diesel Submariner
$$$Alt
G'day Fellas,
I ran into a bloke with a F-Truck in Strathalbyn SA a couple of years ago on his full time on the road haulin' a 5th Wheeler.
He was down in the mouth and in shock recovery from paying $4.5K for an alternator through a Ford Stealership somewhere in NSW .
Poor bugger.
I was at Rapid Bay in SA a couple of weeks ago and another bloke was doin' the same thing full time on the road with a 5th Wheeler and using Ford Stealerships around the country to do his servicing and repairs at a shocking cost.
His missus was getting pissed with the expense and this is where these trucks get a bad rep as too bloody expensive when operated by the poor buggers with no mechanical background or aptitude and only go to Dealerships.
Gotta feel sorry for the poor buggers. But when you try to set them straight you may as well be talking left handed Swahili.
Cheers,
Reg
Old Mar 7, 2013 | 08:15 PM
BigF350's Avatar
BigF350
FTE Emeritus
I wish I was.
Back in 2004 a set of injectors for the 7.3 also cost ~32k IIRC (yes, you could actually buy a full engine with turbo through the parts system cheaper)
I was able to get the cost down on the injectors, but not the alternator.
If you ever have to get parts for your 7.3 from a dealer here (either because its a specific item to Brazilian built units, or because you are in a rush), make sure they contact Ford Australia to clarify/contest the price and rattle the chain, low volume parts can often be priced excessively high by the dealer and by Ford, and despite what you may think/be told, there IS wiggle room, and sometimes quite a lot. (I think the injectors we got down to about 8k for a set, not great - but could you imagine being hit with a 32k bill on parts alone for replacing injectors!)
