Cam Phasers
Old Mar 2, 2013 | 07:21 AM
actech's Avatar
actech
Cam Phasers
Hi all, I have a 2005 Expy 136000 miles with the dreaded cam phaser knock. My engine sounds normal when cold and then starts the knock once it warms up. How can I tell if its the cam phasers, the timing chain or both? Should I just go ahead and do both? I've done a lot of research on the subject and don't want to pull the front cover if I don't have to.
Old Mar 2, 2013 | 11:24 AM
alloro's Avatar
alloro
This is also a classic sign of a bad rod bearing.
Old Mar 3, 2013 | 04:39 PM
actech's Avatar
actech
No, This is definitely not rod bearing noise. All these views and thats the best response?
Old Mar 3, 2013 | 05:11 PM
JWC 3's Avatar
JWC 3
Are you using the proper oil ? Any codes ? I have seen a few make noise with improper oil . Just a thought . If it is the phasers ,not a solenoid issue or oil issue , I would do chains and guides at the same time . Some may not agree , but that is my opinion . And you know what they say about opinions !
jesse282
Jun 20, 2017 04:32 PM
murph154
2004 - 2008 F150
26
Sep 6, 2007 10:44 PM
TigerDan
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 20, 2007 02:21 PM
mattsf250
Dec 9, 2003 06:07 PM
tack338
Nov 13, 2003 11:49 AM
