ABS Code
Old Mar 1, 2013 | 04:12 PM
RIKIL's Avatar
RIKIL
ABS Code
I have an ABS code coming up every once in a while on my RABS 1 system. I understand that when I turn off the key the code is gone so I am trying to figure out how to pull the code when the ABS light comes on.
I looked on this forum and also in my Haynes manual about how to get the codes, it's pretty clear how to count the flashes. What I can't seem to find is the wire I connect to ground in order to read the codes.
The picture in the Haynes manual wasn't too clear and the thread I saw here was different than mine apparently.
Also, if the ABS light isn't on (meaning everything is OK), will any code come up? Since I don't have any codes to pull now, this would be verification I found the right wire.
Thanks.
Old Mar 1, 2013 | 04:31 PM
bashby's Avatar
bashby
Look under the glove box for a single wire connector.
Old Mar 1, 2013 | 04:35 PM
RIKIL's Avatar
RIKIL
OK, found blk/org. When I connect that to ground I don't get anything. Does there need to be a code to pull or will a generic code come through if I do this right?
Old Mar 1, 2013 | 04:38 PM
rla2005's Avatar
rla2005
RABS info
Test connector:
View#2
RABS info from Steve83: 1983 Ford Bronco Brakes & Hubs picture | SuperMotors.net
Old Mar 1, 2013 | 06:02 PM
RIKIL's Avatar
RIKIL
Well that didn't work. I connected the wire to a known good ground for a couple of seconds and released it, nothing. I then held it there for 5 seconds and released, no flashing of the ABS light. It was solid on when I got home so there was a code.
Maybe I have a break in my blk/org wire, where does this wire go?
Old Mar 1, 2013 | 07:21 PM
RIKIL's Avatar
RIKIL
I looked under the glove box and found where the connector is for the org/blk wire. When I jumper the blk/org wire on the other side of the connector, I see the ABS light blink. So I was just using the wrong side connector of the blk/org wire. But should the blk/org wire be connected at the connector? I don't think it's ever been connected and it's never been an issue before.
rmeyer001
Mar 6, 2010 12:57 PM
waywoos
Nov 1, 2004 11:42 PM
Claus
Iowa Chapter
Aug 29, 2004 10:18 AM
whitekknight
1983 - 2012 Ranger & B-Series
Jun 28, 2004 09:19 PM
