7.3 Rebuild...the beginning!
#92
#93
Well this phase of the project is finally done , and I've put about 6k miles on it already. Had a few hiccups like a bad wiring harness for the hpop gauge and a minor oil leak at the bottom front cover bolt, but that was it. For a total re-build and all the factory items I deleted it is pretty amazing the lack of problems. Below are some photos of the completed job with a front shot showing the new grill and 05 headlight upgrade from Riffraff. I just finished the overhead console repair, re-seating the loose chips so now my display works again...!!! Thanks to the FTE Forum is was a breeze to fix. Underway now is I have the dash somewhat disassembled to replace all the gauge panel bulbs, and waiting on the 650 dash kit so I can get rid of the gauges up above the rear view mirror. Once all the interior mods are complete and I have some more nickels saved its off to the paint/body shop and then to upholstery.
PRESSURE TESTING THE INTAKE SYSTEM
I HATE THIS GAUGE LOCATION....CHANGING SOON TO THE 650 DASH KIT.
A BIT DUSTY BUT NO UPPER LEAKS
NEW GRILL AND 05 HEADLAMPS
#94
#96
Thanks. I have a DP Infinity tuner with several performance tunes, however until I get 10-12k miles on the motor I am leaving it in the stock tune. Tooooo much money invested to mess around before a decent break in period. Once I get past that point then it's dyno time. I am hoping to talk John Woods into dialing it in for me and putting on a dyno to see where it at. I am expecting around 600hp but we'll see.
#97
It was ok until I drove it for a bit and then it started to come loose. Velcro no matter how well intended does not work here in the desert areas of SoCal. When I jiggled it I just made it worse so not its all down sitting on my dashboard waiting for the new dash panel.
#101
#102
Thanks!
Thanks Steve!
I'd like to see that when you're done. Hadn't heard of that method yet.
#104
Awesome build! Just read all 7 pages. Stumbled across this on Riff-Raff's Facebook feed. Like others say on here, I'd love to do a similar build. I like your CCV catch/drain - got any more info? As mine routes to atmosphere. I am picking my mods carefully as I live in the Peoples' Republik as well. I once got a note from AQMD b/c my wife accellerated kinda hard and smoked (a prius) - Someone whined. Was a funny letter - I should post it. So I have to deal with the CA smog BS. I find that being stealth is your friend. For mine to pass, I went to the stock tune, removed the tuner, re-connected CCV (Glad I kept it) and I even covered up the orange Garrett logo on the 38R intake tube to make it appear as stock as possible. Even though I spent plenty of time BS'ing with the smog tech, he sure did look everywhere -- even hooked up the computer to the OBD-2 port to see if any codes were lingering...I guess enough time passed so the 1211 fell off. I want to do the reg-return - thinking about Riff-Raff's version, as it seems the least obvious. Do you plan to put the stock HPOP cover back on? May help hide the RR - if the tech is short anyhow.
#105
Since I put it in I haven't had any issues with oil in the boots. Wow, a letter from the AQMD ****'s! Not sure on the HPOP Cover, I bought the stainless steel piece that say's "Powerstroke 7.3L" and I just like the look better without anything. Yeah, being discreet is important. I am trying to convince my wife that we need to move to the Country of Texas before they lock the gates. Have fun if you decide to do your own build. I had a great time!
