Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State/Prov):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Private or Dealer Listing:
Location (State):
460 EFI parts
Old Feb 24, 2013 | 04:06 PM
markfuga's Avatar
markfuga
460 EFI parts
Category: Drivetrain
Price: $10
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): S2000
Item Condition: VA
Engine: Part suitable for gas truck
I have almost 3 engines worth of parts that I need to findnew owners for. All parts are from the Ford 460 EFI engines, mainly 91 and 94model years. You name it and I have at least 2 if not 3 of it. Everything is upfor grabs to reasonable offers (see suggested prices); not trying to get rich,just trying to clear space and see this stuff go to use. Located in Leesburg,VA.
I also have a few miscellaneous truck parts for the sameyears. Here’s a brief breakdown to help. If you’re looking for something and it’snot listed just ask.
3 AC/PS pump brackets - $20 each
2 Alternator/smog pump brackets - $10 each
2 AC delete brackets - $25 each
Crank/water pump pulleys $10 each or $15 per pair
1 New water pump (GMB) - $30
1 New starter motor (NAPA reman) - $30
1 New alternator (NAPA reman) - $30
1 New oil pan - $70
3 cylinder heads: F3TE - $50 each
1 complete short block - $100
1 block disassembled - $50 with crank, pistons, rods
3 complete induction setups – only 1 is still assembled – need a manifold,harness, injectors?
2 air filter boxes with hoses to intake - $20 each
2 cold air snorkels - $20 each
3 sets of exhaust manifolds - $30 per pair
2 flywheels with good ring gears - $20 each
2 radiators – $30 each
3 sets of valve covers - $20 per pair
1 Y-pipe - $20
1 fan with clutch
Other parts:
Pair of F250 XLT fender emblems – normal wearfor age - $10
Pair of F250 Heavy Duty fender emblems – normal wear for age - $10
2 complete sets of front turn signals and side marker lights – 92 to 97 models- $20 per set (set = left and right)
Pair of front coil springs, 97 F250 HD with 7.3 diesel, truck sat up proud, nosag - $50
Front bumper from 97 with black plastic trim – some dings but very presentable- $40
Rear axle from 97 F250, 3.55 with locker, sway bar and new brake pads - $300
Transfer case from 94 F250 that had 460 and ZF5 - $75
Engine run stand - $400 can be seen here:
Old Feb 25, 2013 | 07:33 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Is the flywheels for manual transmission?
Old Feb 26, 2013 | 04:55 AM
markfuga's Avatar
markfuga
Yes. I should have noted all the trucks were standard ZF5 trucks. I have all the bolts to go with them (crank and clutch). I also have 2 PCMs, 1 from a 91 Super Duty (450) and 1 from a 94 250. I can send pics of anything you're interested in.
Old Feb 26, 2013 | 11:37 AM
ManfredVonRichtofen
Yes i am very interested
You sell the zf5 clutch fork, hydraulic line too?
Im doing a zf5 swap in my 79 bronco behind my 460.
Old Feb 26, 2013 | 11:46 AM
markfuga's Avatar
markfuga
Yes, I have 2 clutch forks and 2 master/slave combos that are still connected with the hydraulic lines. Are you putting on new master/slaves? The pair I have are good, no leaks.
Old Feb 26, 2013 | 11:50 AM
ManfredVonRichtofen
Sure. I'll buy the flywheel, zf5 clutch fork, master cylinder and hydraulic line.
I was thinking bout buying a new slave though.
You say this is for a 460 right?
Oh do you have the clutch pedal too? I buy that as well.
Let me know the price for all.
Old Feb 26, 2013 | 12:25 PM
markfuga's Avatar
markfuga
I do have clutch pedals. Does your 79 have a pedal box assembly that will accept a pedal or do you need to replace the pedal assembly?
yes, all these parts are from 460 trucks. PM me your email address and I'll send pics of everything so you can "see before you buy".
Old Feb 26, 2013 | 12:40 PM
ManfredVonRichtofen
Whole assembly. PM sent.
Old Feb 26, 2013 | 02:52 PM
ManfredVonRichtofen
I emailed u
Thanks
Old Feb 26, 2013 | 07:23 PM
ManfredVonRichtofen
I'll take the clutch assembly on the right that you sent a picture of.
Old Mar 1, 2013 | 02:12 PM
DIYiT's Avatar
DIYiT
PM Sent
10 characters
Old Mar 2, 2013 | 05:17 PM
lisagoud's Avatar
lisagoud
F3TE heads
any pictures of the F3te heads (I would take them all if not rotted) anbd the flywheels if available
Old Mar 6, 2013 | 04:32 AM
chad85's Avatar
chad85
valve covers
Do you have a set of valve covers that will fit a 1989 460 EFI? If so I will take a set.
Old Mar 6, 2013 | 05:07 AM
markfuga's Avatar
markfuga
Yes. Your 89 should have the E7TE heads which use the same valve covers as the later F3TE heads, so the 3 sets of valve covers I have will fit either set of heads. Shoot me a PM with contact info and I can get a set off to you.
Old Mar 6, 2013 | 04:11 PM
lisagoud's Avatar
lisagoud
still waiting
still waiting to wrap up the heads, vavle covers and flywheels
