Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State/Prov):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Private or Dealer Listing:
Location (State):
460 EFI parts
Old 03-11-2013, 06:06 PM
460plowtruck's Avatar
460plowtruck
460plowtruck is offline
460 heads
Category: Drivetrain
Price: $10
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): S2000
Item Condition: VA
Engine: Part suitable for gas truck
I need two cylinder heads for 1994 460.I have bad rust issues!thanks.
Old 03-12-2013, 05:31 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
rord efI head
I have one of them all rebuilt and new from the machine shop.PM me if interested/
Old 03-12-2013, 05:57 PM
460plowtruck
call me at 860-716-5637.thanks.mike.
Old 03-12-2013, 05:59 PM
460plowtruck
460 head
call mike at 860-716-5637
Old 03-21-2013, 10:29 PM
BennyLumpkin's Avatar
BennyLumpkin
BennyLumpkin is offline
Pics of the y pipe? Shipping to 16828? Mine is beat up from the previous owner and leaks. Its kinked by where it meets the manifolds.
Old 03-22-2013, 04:31 AM
markfuga's Avatar
markfuga
markfuga is offline
If you cant see the pic of the Y-pipe, send me a PM with you email and I'll send it that way. The pipes are solid, have the O2 sensor and hanger near the cat end of the pipes.
Old 03-22-2013, 06:14 AM
BennyLumpkin
Chfcres4cue@yahoo.com the pic won't load on my phone for some reason. Thanks.
Old 03-22-2013, 05:50 PM
460plowtruck
what is the code number
Old 03-24-2013, 08:49 AM
460plowtruck
F3TE heads
Ineed the F3TE heads.are they complete?I need these shipped.Are you willing to crate these heads?I had a head shipped last week and FedEx cracked three rocker towers.they were only in cardboard box.call 860-716-5637 if you like.I also need smog pump air lines and a lifting bracket,the one on the end of the head .I like your engine test stand,nice job!
Crank/water pump pulleys $10 each or $15 per pair
1 New water pump (GMB) - $30
1 New starter motor (NAPA reman) - $30
1 New alternator (NAPA reman) - $30
1 New oil pan - $70
3 cylinder heads: F3TE - $50 each
1 complete short block - $100
1 block disassembled - $50 with crank, pistons, rods
3 complete induction setups – only 1 is still assembled – need a manifold,harness, injectors?
2 air filter boxes with hoses to intake - $20 each
2 cold air snorkels - $20 each
3 sets of exhaust manifolds - $30 per pair
2 flywheels with good ring gears - $20 each
2 radiators – $30 each
3 sets of valve covers - $20 per pair
1 Y-pipe - $20
1 fan with clutch
Other parts:
Pair of F250 XLT fender emblems – normal wearfor age - $10
Pair of F250 Heavy Duty fender emblems – normal wear for age - $10
2 complete sets of front turn signals and side marker lights – 92 to 97 models- $20 per set (set = left and right)
Pair of front coil springs, 97 F250 HD with 7.3 diesel, truck sat up proud, nosag - $50
Front bumper from 97 with black plastic trim – some dings but very presentable- $40
Rear axle from 97 F250, 3.55 with locker, sway bar and new brake pads - $300
Transfer case from 94 F250 that had 460 and ZF5 - $75
Engine run stand - $400 can be seen here:
[/quote]
Old 03-24-2013, 12:55 PM
markfuga's Avatar
markfuga
markfuga is offline
Parts are flying off the shelf! I'm getting alot of requests lately, which is great, so just thought I would update my list. Also, I've sold stuff that's not on the list becasue people asked if I had a "you fill in the blank" and I did. So if you need something not listed, just ask. For example, I have a new MSD coil for the 460 EFI and a lightly used MSD distributor cap with 8mm accell wires.
3 AC/PS pump brackets - $20 each - 1 left
2 Alternator/smog pump brackets - $10 each 2 sold, found a third pending payment
2 AC delete brackets - $25 each - both still available, make offer
Crank/water pump pulleys $10 each or $15 per pair, sold 1 set, 1 set pending payment
1 New water pump (GMB) - $30 - Still available
1 New starter motor (NAPA reman) - $30 Sold
1 New alternator (NAPA reman) - $30 Sold
1 New oil pan - $70 - Still available with new Felpro gasket. This is a steal at this price
3 cylinder heads: F3TE - $50 each All pending payment
1 complete short block - $100 Still available, tight bottom end, thow on carb heads!
1 block disassembled - $50 with crank, pistons, rods Still available
3 complete induction setups – All injectors sold to a rebuilder, still have everything else
2 air filter boxes with hoses to intake - $20 each Still available
2 cold air snorkels - $20 each - still available, fits all F series with 460 or inline 6
3 sets of exhaust manifolds - $30 per pair - all still available
2 flywheels with good ring gears - $20 each both sold
2 radiators – $30 each still available, one has trans cooler, the other does not
3 sets of valve covers - $20 per pair 1 set sold 2 still available
1 Y-pipe - $20 pending payment
1 fan with clutch, still available, found a second. Both are steel not plastic
Other parts:
Pair of F250 XLT fender emblems – normal wearfor age - $10 still available
Pair of F250 Heavy Duty fender emblems – normal wear for age - $10 still available
2 complete sets of front turn signals and side marker lights – 92 to 97 models- $20 per set (set = left and right) all still available. These parts are expensive from Ford!
Pair of front coil springs, 97 F250 HD with 7.3 diesel, truck sat up proud, nosag - $50 Still available
Front bumper from 97 with black plastic trim – some dings but very presentable- $40 Sold
Rear axle from 97 F250, 3.55 with locker, sway bar and new brake pads - $300 Still available, will part out the gear set, etc
Transfer case from 94 F250 that had 460 and ZF5 - $75 Sold
Engine run stand - $400 can be seen here: Still available... you know you want it
You Tube
Old 03-24-2013, 01:07 PM
markfuga's Avatar
markfuga
markfuga is offline
And by the way... did anyone notice in the engine run stand video that I deleted the PS pump and installed a Chevy (dirty word) 1 wire alternator in the AC position? I was planning to swap this engine into a late 50's truck and didn't need PS or AC and I only wanted to use 1 belt with the tensioner for simplicity. Both of these "home made" brackets are also available.
Old 03-24-2013, 02:58 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
F3TE Heads sold
Money was sent...yes I noticed and I've been doing that for years on 460's plus GM HEI Ignition which is also aweome despite the critics out there. (Duraspark II sucks *** and so does the charging system)>
  #28
Old 04-17-2013, 09:38 AM
jtmalott's Avatar
jtmalott
jtmalott is offline
still have the cold air intakes? pm me
  #29
Old 04-17-2013, 10:32 AM
markfuga's Avatar
markfuga
markfuga is offline
Hi, Yes I still have the cold air intakes. I tried to PM, but I think becasue your post count is low the feature is not enabled for you yet. Send me your zip and I can get a shipping quote. Email me at: mark.fugazzotto@gmail.com
  #30
Old 04-17-2013, 11:24 AM
BennyLumpkin
Mark, did you recieve my email I sent after recieving that y pipe?
Quick Reply: 460 EFI parts
