79 backfiring through carb
Old Feb 24, 2013 | 01:05 PM
dig'umz's Avatar
dig'umz
i have a 79 f-150 with a 351W and a Holly 650 4bbl with a edelBrock preformer intake. hei MSD Distributor -
at 1000x RPM idle to 5000 RPM idle it sounds smooth but when you put it in drive and accelerate it back fires through the carb. iv check'd the plug wires and the plugs they dont seem cracked or corroded checked the gaps on the plugs while i was at it .40 on all cylinders re check'd the firing order.1 - 3 - 7 - 2 - 6 - 5 - 4 - 8 its all correct. could it be just the carb? or how do i check for a frozen valve. im running out of ideas what the problem is.
Old Feb 24, 2013 | 01:10 PM
HIO Silver's Avatar
HIO Silver
Check all vacuum lines for cracks.
Frozen/stuck valve? Pull the valve covers and observe the valve train. A bent pushrod can also cause a miss.
Old Feb 24, 2013 | 01:16 PM
dig'umz's Avatar
dig'umz
is there a vacuum line diagram to check if all vacuum lines are in the right places.
this is my first 351W swap. and iv had nothing but trouble and there was a few things that didnt go back the same way as my old 400m did.
Old Feb 24, 2013 | 01:28 PM
HIO Silver's Avatar
HIO Silver
Diagrams: https://www.ford-trucks.com/forums/1...ml#post1522830
Have at it.
Old Feb 24, 2013 | 01:49 PM
dig'umz's Avatar
dig'umz
ok check vac lines there all where there supposed to be and concidering i used new vac lines when i did the swap theres no cracks or cuts [ i re check them they seem fine.] any other ideas ?
Old Feb 24, 2013 | 02:00 PM
wilcam47's Avatar
wilcam47
is the carb new or is it older? if you have an older one with a rebuild kit it prob doesnt have the blowout port on it... you may have blew a hole in the power vavle...
valve timiming, weak vacuum advance spring or ignition timing can cause backfires through the carb.
Old Feb 24, 2013 | 02:07 PM
dig'umz's Avatar
dig'umz
it was rebuilt a year ago. but then again i think i need to replace it cause idk what the previous owner has done to it. and its outdated. i now think its the power valve. so i ill go rip it off and break it down and go from there. thanks
Old Feb 24, 2013 | 02:32 PM
wilcam47's Avatar
wilcam47
check for vacuum leak around the intake/base of the carb too...if it stays running spray some carb cleaner around the base of the carb and around the intake if the rpms increase you have a leak...
Old Feb 24, 2013 | 04:34 PM
gumshoe's Avatar
gumshoe
check the timeing it , should be around 8-10 deg. btc. worn timeing chain can cause a backfire
Old Feb 24, 2013 | 05:25 PM
dig'umz's Avatar
dig'umz
ill try that. it runs fine at idle.. but now today it starts to back fire on start up its like the carbs over loading itself
Old Feb 24, 2013 | 05:26 PM
dig'umz's Avatar
dig'umz
i also did the smoke trick and didnt see any smoke coming out the lines
Old Feb 24, 2013 | 05:27 PM
dig'umz's Avatar
dig'umz
its not the timing chain or the timing. brand new rebuilt motor. i checked everything and the dist and bug are TDC
Old Feb 24, 2013 | 06:32 PM
dig'umz's Avatar
dig'umz
ok now theres bubbles in my fuel filter.. so i ended up following the fuel lines for leaks or cracks i found a line that was beggining to go bad so ireplace it and all the lines from the fuel pump to the tank. but the fuel filter is still bubbling at idle.
Old Feb 24, 2013 | 09:12 PM
wilcam47's Avatar
wilcam47
? is that with a timing light? or what? If you are timing it with the light to 0 its gonna run like crap! It should be 8-10 degrees advanced like Gumshoe stated before. Also when timing it make sure the vacuum advance is unplugged from the Dist...and the hose is plugged! If not your timing will be off
Old Feb 25, 2013 | 09:20 AM
dig'umz's Avatar
dig'umz
its set with a timing light 8-10
