Question regarding 1965 F100 fenders
I need to replace the passenger fender on my '65 F100. I found one on CL for $40 that is in really good shape, but it's from a '66. Are the fenders on these two years interchangeable? I looked at photos and they look exactly the same, I didn't know if maybe there were some minor differences though. Thanks for your help.
They are the same so long as the wheel arch matches as 2WD and 4WD/ 1 ton rigs use different fenders. Aside from that the lone difference is fender/hood side nameplate location. 65-66 is on fenders. 61-64 is on the side of the hood. 61-62 used large spears on the side with truck model cast in. 63-64 used a chrome bezel w/plastic insert which has model on it.
- cs65
- cs65
Applications: 1961/66 F100/250 2WD & 1966 F100 4WD ~ Use with 15" or 16" wheels.
C2TZ-16005-D Right & C2TZ-16006-D Left .. 45" radius front fenders.
Applications: 1961/65 F100/250 4WD / 1961/66 F350 / 1966 F250 4WD // 1961/66 F100 2WD & 1966 F100 4WD ~ Use with 17.5" wheels / 1961/66 F250 2WD ~ Use with 19.5" wheels.
POS-F500
02-10-2013 08:13 PM
banjopicker66
05-21-2002 03:13 PM
