Question regarding 1965 F100 fenders
Old 02-24-2013, 11:32 PM
jrayyy's Avatar
jrayyy
jrayyy is offline
I need to replace the passenger fender on my '65 F100. I found one on CL for $40 that is in really good shape, but it's from a '66. Are the fenders on these two years interchangeable? I looked at photos and they look exactly the same, I didn't know if maybe there were some minor differences though. Thanks for your help.
Old 02-25-2013, 12:26 AM
Bill W's Avatar
Bill W
Bill W is offline
the 65-66 fenders will interchange without any problem....
Old 02-25-2013, 01:43 AM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
What are the differences between the 61-64 fenders and the 65-66 fenders? Will they interchange what's all needed if say you have a 63 fender and want to put it on a 66?
Old 02-25-2013, 01:58 AM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
They are the same so long as the wheel arch matches as 2WD and 4WD/ 1 ton rigs use different fenders. Aside from that the lone difference is fender/hood side nameplate location. 65-66 is on fenders. 61-64 is on the side of the hood. 61-62 used large spears on the side with truck model cast in. 63-64 used a chrome bezel w/plastic insert which has model on it.
- cs65
Old 02-25-2013, 05:17 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C2TZ-16005-E Right & C2TZ-16006-E Left .. 36" radius front fenders.
Applications: 1961/66 F100/250 2WD & 1966 F100 4WD ~ Use with 15" or 16" wheels.
C2TZ-16005-D Right & C2TZ-16006-D Left .. 45" radius front fenders.
Applications: 1961/65 F100/250 4WD / 1961/66 F350 / 1966 F250 4WD // 1961/66 F100 2WD & 1966 F100 4WD ~ Use with 17.5" wheels / 1961/66 F250 2WD ~ Use with 19.5" wheels.
POS-F500
02-10-2013 08:13 PM
malanr
1961 - 1963 F100 Unibody
07-22-2010 01:22 PM
66 twin i
01-01-2007 11:00 PM
ymurf
02-29-2004 08:38 PM
banjopicker66
05-21-2002 03:13 PM
Quick Reply: Question regarding 1965 F100 fenders
