Starting issue
Old Feb 22, 2013 | 11:34 PM
Leemakesmepee's Avatar
Leemakesmepee
Starting issue
I was driving driving and didnt have any power and it died on the side of the road wouldnt start just turn over i had it tow roped home. I hopped in it the next day it started right up then would die, i had one of my buddys scan it and it gave a code for the cps. now it will turn over but just buck no start though.
Also when cranking it over i noticed it was leaking diesel from what i think is the fuel filter restriction gauge ? its on the right side of the fuel bowl it was a steady drip coming from the gauge when cranking.
Im getting a wts. also the tach is moving when cranking about 200. i also am getting smoke from the tail pipe. Also we took the fuel bowl cover off cranked and it is pumping fuel. I replaced the IDM i want to say last march or spring time. All the glow plugs are good and i just changed the injector o rings in nov.
Truck just hit 300,000 miles around the beginning of the month.
What are some other things i should be looking into ?
Thanks in advanced.
Old Feb 23, 2013 | 07:35 AM
Talyn's Avatar
Talyn
Check oil level and fix fuel leak.
If you cannot build 40PSI it wont start or stay running.
Old Feb 23, 2013 | 01:14 PM
Leemakesmepee
Oil levels good. When cranking no leak anymore. How can do I test fuel pressure?
Old Feb 23, 2013 | 02:03 PM
BRay09's Avatar
BRay09
Fuel pressure test port right by that sensor
Old Feb 24, 2013 | 08:23 PM
sami001's Avatar
sami001
That sensor is either the restriction or water in fuel sensor. Mine started leaking last summer so I pulled it out, took it up to my local ace hardware and found a small square head bolt that matched the threads and put it in. No more leak. I personally don't worry about either of those sensors. I doubt they work anyways, if they do then the lights are out. I change my filter religiously and every week or two I drain the fuel bowl a little just to keep water from building up.
Old Feb 26, 2013 | 10:55 PM
Leemakesmepee
Alright i put a gauge on and when cracking its making over 40 psi bumping around 50 to 60. The scanner says its still the cps. I replaced it with a advanced auto one, but from what ive read is those wont work the best or be bad out of the box. Im gonna go to my ford dealer tomorrow and get a ford cps.
To see if it makes a difference.
Old Mar 3, 2013 | 12:24 AM
Leemakesmepee
Update
Well i bought a cps from ford and put it in and it started right up surprisingly. Im gonna buy another and put it in the glove box as a spare.
Thanks for the help guys.
ParkerCC2
Feb 6, 2017 06:29 PM
strokerspeed
64
Jul 7, 2011 08:53 AM
mercedes4oil
16
Feb 25, 2011 11:51 PM
Gene W
Sep 12, 2007 04:42 PM
danny0
Dec 18, 2005 05:58 PM
