help
Old Feb 22, 2013 | 02:01 PM
123skeeter's Avatar
123skeeter
help
i have a 99 f350 7.3 i just got done putting glow plugs and vavle cover gasket on. test drove and the truck has no power and CEL came on. got the scanner on it and it said 1316 code. so i took everthing back off and check all of the wires and plugs. look good and tested good. then i buzz tested the injectors number 8 tested bad. dont want to spen the money if i dont have to. if someone can point me in the right way ill be happy
Old Feb 22, 2013 | 02:05 PM
jeffreyt's Avatar
jeffreyt
I would first say to check the harness. If it was fine before, and now it's not, maybe you didn't get it plugged in good. And if you used a new gasket, check for continuity. Could be a faulty new gasket.
Old Feb 22, 2013 | 02:09 PM
123skeeter's Avatar
123skeeter
yes its a new gasket and i did that all morning
Old Feb 22, 2013 | 02:12 PM
123skeeter's Avatar
123skeeter
what are the odds of the number 8 injector crapping out right after i just got done changing everthing
Old Feb 22, 2013 | 02:16 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Slim.
However, the chances you bumped the metal retaining clip for the solenoid connector is far greater.
It's happened to me once so I am more careful when installing the valve cover nowadays...
Old Feb 22, 2013 | 02:25 PM
123skeeter's Avatar
123skeeter
i was thinking that myself so i took everthing back off and doudble check i still have valve covers off in my shop im not putting them back on intill im right
1'stonraceday
Mar 25, 2014 07:16 PM
Groundpounder0331
May 21, 2013 06:54 AM
nmpontiac
21
May 10, 2013 10:16 AM
hndamxmn
Apr 28, 2009 06:15 PM
sparkroost
Aug 10, 2006 11:02 PM
